Nortel T7316E 2-Line Corded Phone Logo
Posted on Apr 13, 2009
Speed Dial Numbers
How do I program speed dial numbers. Not spee dial buttons.
Anonymous
Level 1:
  • Contributor 27 Answers
  • Posted on Apr 20, 2009
Anonymous
Contributor
Level 1:
Answers
27
Questions
Helped
30934
Points
51
You have to go into system programming . Press the feature button then the star key two times and then the password which is 266344 by default . so it should look like this . F ** 266344 and then repeat the password 266344 . now that you are in you look for the heading speed dial numbers . if you need help to find the heading then you can call me and I can walk you through it . My name is Efren and you can reach me at 626-712-5753 m-f 9:00 am to 5:00 pm pacific time .
3helpful
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Hi I have a panasonic KX-T433 phone system which I am trying to put in speed dial numbers, we have to dial 9 to dial out does any one know how to do this using a 9 in front?
You have neither a 7730 (the category you asked in) or a 7433 phone sytem. If your phone is really a 7433, you have a TD phone system. Which "speed dial numbers" are you trying to program? System speed dials, are stored in system program 001 and consist of a 3 digit number (may be 2) with a "9" in front and the number as you would dial it from the keypad. Personal speed dial numbers depend on the button you're programming it onto. If it's a button with a light, you dial "2" in front of it. If not, you don't. So, Program 99, button, and either 29 + number STORE or 9+number STORE programs a personal speed dial.
There are other programs to store under the tone pad keys. Those features are covered in your User's manual for the TD system.
Carl
Forumla for adding speed dial numbers
Personal speed (the 12 F buttons on the right) depend on whether you dial "9" to get an outside line. Then the buttons are programmed by pressing PROGRAM the button and dialint the speed dial number with a 9+ then STORE. System speed dial number sare programmed in SYSTEM programming 001 and they have "9" also in front of them.
Carl
1helpful
3answers
How do i reprogram my speeddial numbers on jazz 4400?
Although I've been unable to locate a User Manual specific to your phone, the following information pertains to programming most all NorStar phones:
To Program Buttons On Your Phone:
For External Numbers:
1. Press the Feature button, then * 1
2. Push the button you want to program
3. Display will read "Program and OK"
4. Enter the telephone number, then press the OK softkeyFor Internal Numbers (Extensions.:
1. Press the Feature button, then * 2
3. Display will read "Intercom #:__"
4. Enter the extension number
For Feature Codes:
1. Press the Feature button, then * 3
3. Press the Feature button then enter the Feature Code
To Change the Contrast of the Display:
1. Dial the Feature button, then * 7
2. Press the number keys 1 - 9 to your desired brightness level
3. Press the OK softkey
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 - 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.)
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94. that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
Additional information about NorStar phones can be found by clicking here:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
How to program speed dial for various customers
1) To program a personal speed dial number, leave the handset on-hook. Press ALM/SD followed by the DSS button where you want to store the number. Dial the telephone number to save, up to 30 digits (press HOLD to insert a 3-second pause or MSG in insert a hookflash). Press ALM/SD to store the number.
2) To dial a speed dial number, select an outside line. Press the ALM/SD button. Dial the desired speed dial code 10-98 (system speed dial) OR press the desired speed dial button on your phone (personal speed dial).
3) System speed dial numbers may only be programmed by the system administrator.
1helpful
How do I programm the Speed Dial on my 4406D+?
To program your Personal Speed Dial numbers, make a list of
your telephone numbers/extensions numbered 1 to 24, then:
Press an Intercom button + lift handset + dial #00 + dial # + list number (01 to 24) + dial *21 + the number you want to store + #*00.
To use Personal Speed Dial:
1: Press an Intercon button.
2: Press Feature (if you have programmed a "Feature" button) or #.
3: Dial the two-digit code (01 to 24).
1helpful
2answers
Speed dial
I have posted a video showing how to input telephone numbers into your directory. You decide which speed dial entry to use with which phone number. To access Speed dial easily either program a soft key to be an SPD button or the short code is 16followed by the speed dial number. look at 'abbeytel' on YouTube or www.abbeytelecom.com.
6helpful
3answers
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
NorStar T7316E Corded Phone Manual
1 you can but it must be done via log on to switch with lap top (you may use handset but very tricky)
2 use feature *4
Speed dial -
using
FEATURE 0
Dial an external telephone number using a two- or three-digit code. There
are two types of speed dial codes: system (01-70 or 001 to 255) and
personal (71 to 94). System speed dial codes can be used from any
display telephone in the system. System speed dial codes are assigned by
your System Administrator.
Personal speed dial codes are used exclusively at your telephone.
To make a call using a speed dial code:
1. Press FEATURE 0.
2. Enter the two- or three-digit code for the number.
Speed dial -
programming
To program personal speed dial numbers:
1. Press FEATURE *4.
2. Enter a two-digit code from 71 to 94.
3. Specify the external line by pressing a line button, a line pool button, or
the intercom button. If you do not specify the external line, the system
automatically chooses a line for the call.
4. Dial the telephone number you want to program (up to 24 digits).
5. Press HOLD.
6. Record the code and number you have just programmed.
Note: You cannot program personal speed dial numbers while another
user is programming your system.
Top Nortel Lands Phones Experts
vince
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
