Jilbere De Paris Jilbere Euro Waxing System Tea Tree Wax Logo
I brought my waxing system to my mom's so I could wax her and my aunt the lid to the wax came off in my container of waxing necessities : waxing cloths several sizes, wax cloth rolls -3, 20 -prewax disposable washing packets, 20-after waxing disposable soothing packets, several different soothing sprays and lotions for after waxing, chamomile cleansing soap, Orange stick of various shapes, waxing tools, thank goodness most of these were in separate ziplock bags but the waxing machine and extra protective lid rims and lid were not. I do not want to ruin my machine I took us 5 hours of various soaps, lotions, rubbing alcohol, Nail polish remover, vinegar, to get most of it cleaned up including the sink, My waxing machine I wrapped up in newspaper so I can get information on how to clean the outside and power cord clean without wreaking it. the wax was a can of jilbere with the brown lid. how can I safely remove this product off the outside of my waxing machine? what can I use?
Olympia toilet fitted six months ago leaks when flushed
Then the wax seal was put on wrong. If the toilet rocks it will ruin the seal. once the wax is squeezed it can't be moved. Sometimes the wrong thickness of wax was chosen. If a new floor was put down the flange may have required a booster kit before putting the seal on
29helpful
Need instructions on how to use Dr. Scholl's Thermal Therapy Quick Heat Paraffin Bath -- how long to leave hands/feet in melted wax, how long to leave wax on, what to do after removing wax any...
How to fill your Dr. Scholl's Thermal Therapy Quick Heat Paraffin Bath1. Take the lid off your bath container and remove all packing materials.2. Place the unit on a flat, heat-resistant surface.3. Remove the plastic rack.4. Remove all three blocks of paraffin wax from the plastic wrapping. Each block is equal to one pound of paraffin wax, and three pounds of paraffin wax are needed to begin using your Paraffin Bath. Break each block in half, then in half again.5. Place the blocks of paraffin wax in the Paraffin Bath container.6. Plug the unit into an electrical outlet. The green light will glow. The red "Heater" light will initially come on and then cycle on and off while the wax is melting.7. Replace the lid and turn the switch to the "high" position. The paraffin wax will be ready for use when it is visibly melted (approximately 120 minutes).8. As soon as paraffin wax has melted, place the plastic rack on the bottom of the heating chamber. This will protect hands, elbows, and feet from heat.9. Turn the dial to the "Keep Warm" setting and wait 25 minutes before dipping hands, elbows, or feet.
Warning: DO NOT place hand or any other body part inside the chamber while the unit is melting the wax.
How to Dip Hands1. Remove jewelry, roll up sleeves, and thoroughly wash and dry hands. You can also rub in some of your favorite hand lotion.NOTE: The lid should be on during the time the unit is heating. Put the lid back on the unit after each use.2. Put a small amount of wax on the inside of your wrist to test the temperature.3. Spread fingers apart slightly and slowly immerse your hand in the paraffin wax container. Then immediately, but gently, remove your hand from the Paraffin Bath chamber. Let the paraffin wax solidify on your hand. Wait at least three seconds (until the paraffin wax no longer appears shiny) before redipping. Be careful to avoid touching the sides or the bottom of the Paraffin Bath chamber.4. Continue to dip your hand in and out of the paraffin wax, following Step 3, to build up layers of paraffin wax. For the best results, do this at least five times. The more layers, the longer the heat will last.5. If desired, cover your hands with glove liners and place your hands in the insulated mitts. These retain heat for better results.6. Remove the hand mitts from your hand. Remove the plastic glove and discard. Peel the hardened paraffin wax from your hands. It is recommended that the hardened paraffin wax be discarded.7. Massage in the oils left on your hand after the paraffin wax is peeled off to get the full invigorating and rejuvenating benefits of your Paraffin Bath.NOTE: Allow the paraffin to remain in place for 10-15 minutes before removing; longer if more layers exist or if the mitt has been used previously.
To Treat Feet or ElbowsFollow steps 1-4 as outlined for hands. Mitts are intended for use with hands only.
Product Care and Maintenance Place paraffin bath in a safe, cool and dry place when not in use. Wipe with a soft, damp cloth. DO NOT use abrasive cleaner. Never submerge the unit in any liquid. Keep away form all solvents and harsh detergents. DO NOT attempt to repair this paraffin bath. There are no user-serviceable parts.
STORAGEWhen not in use, "unplug it."Allow appliance to cool and store out of reach of children in a safe, dry location. To protect from dust or dirt, simply store in its original box. Never wrap the cord around the appliance since this will cause the cord to wear prematurely and break. Handle cord carefully for longer life and avoid jerking, twisting or straining, especially at plug connections.
CLEANING INSTRUCTIONSRemove plastic rack from heating chamber.1. DO NOT unplug the Paraffin Bath. Allow paraffin wax to remain undisturbed for a few minutes.2. Turn unit off and let the paraffin wax "harden."3. Right before cleaning, turn the unit on again until the paraffin wax is visibly melted around the entire edge (approximately 3-5 minutes), then turn unit off and unplug from the electrical outlet.4. Spread an ample amount of paper towels on a hard, flat, heat-resistant work surface and slowly turn the unit upside down to allow the hardened paraffin wax to drip from the chamber onto the paper towels. Allow the surface of the paraffin wax block to harden and then discard it. To clean the empty chamber, wipe with paper towels to remove any sediment.5. To clean the outside of the unit, remove any solidified paraffin wax.6. DO NOT use sharp objects to remove solidified paraffin max.7. DO NOT scratch or damage the Paraffin Bath chamber.8. DO NOT use abrasives when cleaning the Paraffin Bath chamber as it will damage the finish.9. If you discard the paraffin wax after each use, we recommend you clean out the unit completely every 40 uses. If you re-use the paraffin wax after every use, we recommend you clean out the unit completely every 20 uses.
PLEASE NOTE: This appliance should not be used in the presence of open cuts or wounds, inflammatory skin conditions, growth peripheral vascular disease where circulation is impaired, acute inflammation, or where sensation of the extremity is reduced or absent. If there is any question about peripheral vascular disease or decreased sensation of the extremities, consult a physician or physical therapist before using the Dr. Scholl's Thermal Therapy Quick Heat Paraffin Bath. Discontinue use if dermatitis due to paraffin sensitivity occurs. Discontinue use if wax feels too hot or cool, which could indicate health problems with the user.
There are also a bunch of standard warnings about dealing with electric appliances. Take care of them, don't dump them in water, etc., etc., etc.
It's worth pointing out that paraffin wax is flammable.
3helpful
2answers
We lost the factory manual. Once the wax is heated please guide us through each step and the duration? Any help would be greatly appreciated. Thank you so very much and God Bless!
My dispense soap lid does not open all the time.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Washer doesn't understand that the lid is closed and won't run. I took the lid off and tried to manually push in the swith but no luck. Washer is a Maytag Atlantic MAV6250
Door lock replacement vid and more good stuff
Bonus stuff: Wax motor 101 featuring R11 and Q6 swap out and other cool stuff
Note: both the motor control and the central control has to know that the lock is in place, so the wax motor does 2 things! It locks the door and then sends info back to the central control and the motor control on various models. So the wax motor is crucial. A red wax motor is a new and improved wax motor. What other smart pills have I got? Let see: Neptune washer manuals
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Trouble changing hearing aid batteries
i'm not aware of a tool to change batteries but Eveready sells hearing aid batteries that have a magnet on it so that you can put them in you aid easier. You can buy them at Walgreens ir CVS.
Top Jilbere De Paris Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Jilbere De Paris Health and Beauty Expert? Answer questions, earn points and help others
