Question about Electric Health & Beauty
Jazzy 1143 power chair
I have 4 yellow bars and 3 red bars flashing rapidly. No pauses in between. Manual says right motor disconnected for 4 yellows and left motor disconnected for 3 reds. Have the shroud off, but do not see any wiring disconnected. Batteries are fully charged, but chair doesn't run and it won't turn on unless connected with the charger cord.
  • Judy Johnson Sep 04, 2013
    I know what the problem is, just don't know how to fix it.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
Well if u need the charger on then batterys are dead and need to be recharged,or have the batterys checked make sure they are ok by testing a load on them at a local auto parts store for free,if no good make sure u get same type of battery and make sure it is a gel battery not a acid battery
Posted on Jan 20, 2014
SOURCE:
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
How can I get this chair to work
Pride Mobility Products Download the trouble shooting information for your model chair.
Aug 29, 2016 | Pride New Jazzy 600 Power Wheelchair by...
Yellow invacare wrench
Motors must be fully locked in gear to drive. Also many chairs require the joystick to be turned off before putting them in gear or turn chair off and back on after engaging the motors.
Dec 23, 2013 | Pride Jazzy 1103 Ultra Standard Power...
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
On off switch lights the red yellow green readings at full strength but continues to just blink when turned on.. get no response trying to use the joy stick. - the seat riser and speed buttons show no...
YY count the number of flashes ie 4 flashes pause 4 flashes pause. This will give you the error code and will tell what is wrong with your chair Check out my tip on Flash codes if you can't find them in your manual. Without fixing the problem that generated the flashing you won't be able to use the chair until the problem is fixed. If you want you could contact the provider that sold you the chair and have them troubleshoot the problem for you Hope this helps
Mar 07, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Not sure witch jazzy chair i got but the joy stick blink and keeps blinking i have tried pushing horn button twice and also turning it on and pushing joy stick forward waiting for it to beep but no beep....
The jazzy probably has a VSI controller and if it is sleep mode then the lights will scroll rather than blink. Now turn on the chair and see if the blinks have a pause between them, ie 4 blinks pause 4 blinks pause etc If they do count the number of blinks and this will give you the error code ie 4 blinks right motor 3 blinks left motor your owners manual should have a chart listing the error codes If not you can contact Pride tech support @ 1-800-800-8586 ask for jazzy tech support
Hope this helps
Feb 17, 2011 | Pride Jazzy 1103 Ultra Standard Power...
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
I have a Pride 1143 Jazzy Electric wheel chair and the controller is constantly flashing. This happened after I drove into my van and locked into the e-zloc. My husband sid I drove in too fast and caused...
Hi
Rapid flash of lights indicates a fault in the VSI or the electrical system. You need to refer to " VSI Error Codes" on page#32 of this User Manual:
Pride 1143 Jazzy Electric wheel chair User Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 25, 2009 | Select Jazzy Used Electric Wheelchair
Health & Beauty Logo
103 people viewed this question
Top Electric Health & Beauty Experts
Rob Hill
Rob Hill
syaiful ridlo
syaiful ridlo
deton8 von Splosion
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
