SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
SOURCE: life fitness 95ti belt moving to one side any way of correcting
If the walking belt has shifted to the left, use the Allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left rear roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centred.
SOURCE: One of our Life Fitness 95 Ti treadmills had smoke
remove the motor control box from under the hood, there is the motor control board (mcb) and capacitors inside the box remove the mcb and check for damage and /or burnt electrical smell also inspect condition of capacitors (4 round cylinders)
if this is the cause you need to get the board repaired
contact glide fitness products in santa ana california 1866 637 4600 for all information including shipping details i have had many repaired by them .the cost is $200 which is a deal considering a new one is $1000
the most common reason for mcb's burn up is a resistor blows due to overload caused by too much friction between the belt and deck board ,and that could be the result if you have an auto waxer nozzle that is plugged up . these nozzle should be cleaned out once a month
note that glide has a non clogging wax to eliminate this issue you ask them about this as well
if you have to send out for repair , make sure you remove the wax board and small electrical component on outside of box and keep them in a safe place as you will need to reinstall them on the new box good luck
SOURCE: Which treadmill should I get?
Dear Sir, all depend how much do you want to spend
Guide from some friend, relative or some nutrional instructor.
God bless you
