Question about Jason Natural Cosmetics Jason Forma 72x36x22 Oval Combo Air-Whirlpool Tub - AC630
Fridge not cooling! But the Fan and light is working! HELP!!
We moved recently and I decided not move my fridge with the help of my brother in law using a dolly.  We moved it down 3 story using stair case and it came down banging every step one at a time.  So, we get to the new house and we plug back in the fridge.  Lights go on, fan is working for freezer and fridge both, so we though everything is fine.  But next morning, all the frozen food was defrosted, my milk didn't feel cold (like before).  We change the setting for freezer and fridge to colder and gave it another day but still no improvements.  Fan seems to be working fine for the freezer but the air is not cold.  I dont know much about fridge but i checked out the compressor and all i found was that when i touched the compressor, it was hot but not hot enough to burn me.  I could actually keep in touch with it for few seconds before i get the burning feeling.
THis is all i could tell you please, help me!! Thanks!
  • 88 Answers
Sounds like you have caused a leak in the sealed system and the coolant is no longer inside it. You will need a professional to fix this.
Posted on Apr 16, 2009
SOURCE:
GE Water Cooler Cold Water does not come out, Why?
It works like a fridge or ac. When its charge gets low it can't cool. It will cycle on and off as freon goes around the circuit. Must be leaking around seals or crack in line. A good ac man could check its pressure to determine. Also, thermostat could be going bad, I would check that as well.
Feb 17, 2013 | GE Profile PXCF22RBS Hot and Cold Water...
I have a Biasi Riva Advance HE Combi Boiler. The pilot light and fan dont seem to be working, I can hear a click when I run the hot water tap and a click after I turn tap off,
Have you bleed the air from system and run hot water and heating at the same time , bleed the pump . you could have air in the pilot after turning it off
May 01, 2017 | Water Heaters
I intend to replace my Reliance 501 water heater unit from inside the house out against the outside wall. Would you please advice me what steps I have to follow ?
Moving a water heater outside is not a good idea because of freezing and increased electricity usage. If you are set on moving it, I would recommend moving it to a garage instead of the outside.
Which ever way you decide to do it, you will need to make sure you build a flat platform for it and that you run a new electrical line from the circuit breaker panel to the new location. I would also recommend that you install an exterior electrical box near the new location. Make sure that you use armored cable from that box to the connection on the water heater.
Now you have to tackle the water lines. You will have to run the cold water line from its present location to the new location of the water heater and the new hot water line back to the old water heater location. Make sure that you insulate all lines not once but twice. A heat tape installed on both lines would also help with freezing.
Aug 16, 2011 | RELIANCE ELECTRIC WATER HEATER
Its not working and just comes u with fault 61
Fault 61. Combustion fan failure. Check wiring. See if fan moves freely
Apr 21, 2011 | Water Heaters
I have a GE MWF water filter that is dripping water into the refrigerator. Fridge is about 8 yrs old and have changed many of the MWF water filters. 1st time with this problem.
Many times fines from these filters become dislodged and plug up the filter housing. If you have the bypass plug for the filter, install it and run a couple gallons of water through fridge to flush the system completely. The install the filter again. Make sure none of the water lines feeding fridge are pinched or kinked and valve is on all the way.
RJ
Nov 30, 2010 | General Electric GE SmartWater Household...
Boiler not working
When the fan stops working it also stops the boiler. Safety.
Check that the fan is turning and blowing air out. You can hear it turning at the top of the boiler and at the vent pipe exit.
With the electrics off, remove front cover and test the fan by moving the blades by hand. Any element of stiffness or jerking or if the fan does not turn freely - replace. These have an induction motor - no repair
Check the electrical contact wires to fan are ok. If the fan is ok check also the 2 plastic tubes to & from the air pressure unit [usually close to one side of the fan] are intact [no splits or holes and will maintain pressure and vacuum] and fully connected to their metal terminals.
Next is to examine the pcb (the electronic board behind the switches) Look for any block connections loose and any obvious signs of black marks on the board. If the latter, replace
Mar 17, 2010 | Water Heaters
Whirlpool Refrigerator/Freezer not cooling
Unplug from wall and let unit subside 1 hour. then plug back in and check operation. Was unit tilted or moved prior??
Please rate. Thank you. jj505
Mar 28, 2009 | Jason Natural Cosmetics Jason Forma...
Eractic Power Vent Gas Water Heater
Th epproblem you are most likely have is from a safety called a flag switch usually located either in the blower or right past it. When you unplug and replug you reset the switch. Sequence of events.  1 fan comes on. 2 switch is made from the airflow of the fan.  3 ignitor come on 4. main gas valve opens and ignitor starts flame.
You are being stopped at step 2 when the fan does not move with the air. This shuts off and out the water heater from calling again.  Find the fan switch and make sure it moves easily. They get dirty and also dry from lack of lube. Good luck.
Mar 16, 2009 | Water Heaters
Tankless water heater pilot light will not stay on
It is most likely the water valve stuck open, telling the controls to heat water, that it thinks is flowing through it, but without actual flow it overheats. Depending on how comfortable you are with taking it apart yourself, you could open the valve to see if it just needs cleaned out, or if you have a ruptured diaphragm or some other cause.
Jan 25, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Jason Natural Cosmetics Jason Forma 72x36x22 Oval Combo Air-Whirlpool Tub - AC630 Logo
384 people viewed this question
Top Jason Natural Cosmetics Water Heaters Experts
Donni Steen
Paul Carew
Are you a Jason Natural Cosmetics Water Heater Expert? Answer questions, earn points and help others
