Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
SOURCE: Automatically powers off, flashing red LED
try removing one neck board at a time and see if it stays on and longer,don;t let the board touch any metal or a short wil follow and you got problems.try the red first,
SOURCE: TV turns off and power light blinks unpluged andd still does it.
Likely to be the STK convergence chips causing a protection circuit to switch the TV off. Have you got any onscreen convergence problems (i.e, colour fringes)?
SOURCE: toshiba TP43H95 projection tv has power but no picture
If it shuts off and then the power light starts blinking red or it never comes on but the power light just blinks red continuously that is usually indicative of the convergence ICs (STK 392-110). You never want to replace the ICs without also replacing the resistors that are associated with them. There are usually 6 resistors, one for each of the colors and there corresponding direction, IE Red horizontal, red vertical, blue horizontal, ect. In the case of this model tv all of the resistors are 2.2 Ohm and 2watts. You will find them right where the STK 392-110 ICs are. Right in front of them. They are blue and have this color code on them. Red, red, gold, gold. These are represented by stripes on the resistors. You can get the parts from www.bdent.com They carry the ICs and the resistors. If you do not feel comfortable completing this repair I could do it for you if you send me the board. My email address is: [email protected] The cost is 375.00 and that includes parts.
Good Luck.
SOURCE: I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
SOURCE: My Toshiba tp50h95 50" rear projection television
If you don't have necessary tools and test instrument and can't
troubleshoot the unit yourself, I would advice you to look for a professional
to isolate the problem. Also, check if your unit is still under warranty/extended warranty
period, avail it because the manufacturer will fix it for free. Opening the
back cover will void the warranty. Hope I helped you. Have a nice day! Thanks for using Fixya.
This kind of symptoms indicated of convergence circuitry failure. The affected parts is the 2 convergence IC's (STK-392-110) and some of the fusible resistors (low resistance resistors). If you are going to DIY, you must have a multimeter to test the resistors' resistance. After you've pinpoint the faulty resistors, replaced them together with the IC's.
Prepare necessary tools like soldering iron, desoldering pump, philips screw driver.
Let me know if your handy with electronics and I will guide you fixing it yourself.
