CLICK HERE for your owners manual in PDF format.
This phone does not have voicemail capabilities. Your company's voicemail system is seperate.
You can find Voivemail notification settings on page 10 of the manual.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
How can I set up voicemail on kt-dt343?
SOURCE: How do I transfer a call directly to voicemail?
If it's a Panasonic voice mail system you program a button for VoicemailTRansfer. Pick an unused button and label it VTR. Now, you need to know what the access number is for voice mail. It's usually 165 or 500. Then you press PROG the button and dial 94+ whatever number VM is and ENTER.
On the original installation, your installer should have at least given you 2 buttons, one for record and one for transfer. We usually give the customer a 3rd button called 2-way transfer. If your system is a TVA, there is a patch to record conversations as new messages, and if you have the optional LAN card(on the 50, it's already in the 200) for voice mail to email, it can send out the wav file at the end of the call.
Carl
SOURCE: panasonic kx-t7633
On the intercom dial *71x1 where x is 0 for all calls, 1 for outside calls and 2 for intercom calls. *71x0 cancels, or you can just press the FWD/DND button until it goes out.
Carl
SOURCE: Checking voicemail remotely on Panasonic KX-T7633
If it's a Panasonic brand voice mail, when it answers, dial #6 * and your extension. Now you can put in the password.
Carl
SOURCE: Change date for KX-t7633
Enter System Programming and choose option 000 the time and date are both settable from there.
Carl
SOURCE: KX-T7633 Voicemail rings
The Voice Mail feature is set by your phone company, not by the phone. Typically the phone company will set it for 20 seconds, or approximately 4 rings. This is called your voice mail "Ring Cycle"
Call them up (the customer service number should be on your phone bill) and they should be able to increase or decrease your ring cycle for you at no charge.
