Can you use SDHC when manual says SD?
An SDHC card is not an SDHC card. While it fits into the same slot, it will not work unless the device is designed to also work with SDHC cards. SD cards go up to 2GB in size, SDHC cards go from 4GB to 32GB in size. Unfortunately, Vivitar seems to be a little fuzzy on the distinction between the two.
In your particular case, you should be able to use any SD card, or any SDHC card up to 16GB in size.
