Need pwr 115 dual banana speaker plug in crossover board
SOURCE: speakon cable to amp
Check the wire's insulation for ridges or striping; if the insulation is clear check the color of the wire inside. Then check the source of the wire to determine which polarity is connected to which wire. Once you know the polarity of the wires at the source, it should be easy to determine the polarity of the wire at the destination. The wire closest to the particular banana clip is most likely the one connected to it. If all else fails, you could use an OHM meter.
SOURCE: Pioneer VSX-815 speaker wiring
You can hook them up either way, the banana jacks are good for hooking two speakers to one terminal (ie one through the botton, one banana) but the electrical connection is the same either way. Sometimes the banana capable jacks are on speakers A and speakers B, and the surround don't accept banana plugs, your stuck with how your reciever is wired.
SOURCE: Using JBL 4410 3-Way crossover, trying to use PG 12" Dual 4-ohm
ok, connect the amp positive to the positive end of one sub coil, take the negative of that coil, and run it to the positive of the second sub coil, then run the negative out of the second sub coil to the negative of the amp.
SOURCE: The speaker cables has "banana
If they're a fixed spacing that doesn't match the spacing of the black and red speaker terminals you'll need to either chop them off and replace them with individual tips or just wrap the twisted bare wire ends around the base of each post and crank 'em down. Make sure no strands are touching anything but the intended post.
http://www.hdwise.com/product.php?productid=522
http://www.flickr.com/photos/frankharveyhifi/4617863847/
14-gauge lamp cord still works fine.
Testimonial: "Spot on, that's exactly what I did and it works fine. many thanks"
SOURCE: i have a bx4500h and
does the cab have a horn like the one in the photo if it does then you must think again.
you must try to get a replacement crossover or get a speaker geek to fix it for you its not so hard you can get the burnt out components fro radio shack / maplin so on. most of the blown components will show damage or smell like they are burnt because thats what they are.
the cross over plays a very important job in the fact that it filters of the top frequencies so you only get subs on the bottom 12's bass / mid on the top 12's and hi frequencies on the horn.
you will loose all the quality if you go direct and could easily blow things up especially the horn.
this speaker cab looks like a Kenny i had and when working then they are fantastic. i blow one of the sub 12's and the cross over survived so unplug the speakers and test them 1 by one with a little power from an amp and a small amp that does not matter if it gets damaged
