Re: Propert Digital bathroom scales only reads half of...
If you want to measure accurate weight of your body, then you should to use Omron HN-286 Digital Slimline Bathroom Scale which uses
4 sensors for greater precision in order to accurately measure body
weight.
The best day chessboard type is the traditional type of weight, in contrast, electronic weight scale error degreehighestelectronic tems, affected by environments, bumps can make reading deviation.The use of electronic weight meter can more precisely? Electronic scales are generally placed in the hard flat floor use, not on the carpet or other soft object surface by using.Each weight to body weight in the same place, the same time, wear the same clothes. Hello, I just see a online stores http://www.tmart.com/Digital-Scales/ sell digital scales. Some advice, for reference purposes only and finally I wish you luck!
I would contact the Company that makes the scales and inform them of their defaulty scale that you paid your hard earned money and see what they say, They may replace it if you send them the defaulty one! Good luck.
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
