1997 Mazda Protege Logo
Posted on Apr 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace the serpentine belt of protege 5 2002, also need the routing diagram
Patrick Rayome
Level 3:
  • Mazda Master 1,757 Answers
  • Posted on Apr 10, 2010
Patrick Rayome
Mazda Master
Level 3:
Answers
1757
Questions
0
Helped
1558275
Points
6122
Posted by Asker under 1997 Mazda Protege for their 2002 Mazda Protege 5.
Both are included Below
Click on the following free direct Link. It has the Belt Diagrams for the 1997 Mazda Protege with either the 1.5L DOHC In-Line 4-Cylinder or 1.8L DOHC In-Line 4-Cylinder Engines; along with various engine options (AC/No AC, etc.). Included are Instrucional Diagrams for loosening (for removal) and tightening (for replacement) using the Adjustment and Locking Bolts/Nuts.
http://www.2carpros.com/car_repair_information/year/1997/make/mazda/model/protege/1997_mazda_protege_drive_belt_routing_diagram.htm
Click on the following free direct Link. It has the Belt Diagrams for your 2002 Mazda Protege 5 2.0L DOHC In-Line 4-Cylinder Engine; along with various engine options (AC/No AC, etc.). Included are Instructional Diagrams for loosening (for removal) and tightening (for replacement) using the Adjustment and Locking Bolts/Nuts.
http://www.2carpros.com/car_repair_information/year/2002/make/mazda/model/protege5/2002_mazda_protege5_drive_belt_routing_diagram.htm
Let me know if this helped, or if you have additional information questions. Feel Free to contact me at FixYa.com!
I need a diagram for a 2011 dodge 2500 cummings serpentine belt.
Jeff, Check the attached links,instruction and guides, diagram for a serpentine belt, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amps Belt routing Installation and system start up for 6 7L Cummins
Serpentine Belt Routing
Drive belt routing
2011 dodge 6 7 cummins serpentine belt diagram Google Search
I need a diagram for the serpentine belt on a 2003 Rav4
Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
Alternator belt replace
Hoe to replace serpentine belt on 1998 mazda protage
there is a tensioner around the engine (it looks like an idler pulley) there will be a 13-15mm bolt that moves the tensioner to the 'slack' position, while you are holding that tenioner slack you need to remove the belt from one of the pulleys ( usually the highet pulley is the easiest) then just reverse the order of the procedure to install the new one.
*** PAY CLOSE ATTENTION TO HOW THE BELT IS ROUTED***
****DRAW A DIAGRAM THAT YOU CAN UNDERSTAND TO BETTER HELP YOU WITH THE ROUTING****
8helpful
2answers
Trailblazer serpentine belt diagram
Hi, first, keep this diagram around as you will need it to route the serpentine belt when you reinstall it. There may also be a diagram under the hood by the radiator.
7e98dff.jpg Next, follow this link and watch the video that shows you how to replace a serpentine belt...
http://www.wonderhowto.com/how-to/video/how-to-inspect-and-replace-your-car-s-serpentine-belt-267229/
Take care
2helpful
How to change the Serpentine belt on a 2008 lancer?
First, you need to have the diagram for how the belt is routed when you replace it.
Serpentine routing diagram...
Here is a link to a video on how to replace the serpentine belt. I hope it helps!
http://www.wonderhowto.com/how-to-inspect-replace-cars-serpentine-belt-267229
7helpful
2answers
Need diagram of drive belt assembly forcaddy
You didn't list your motor size so please pick the applicable diagram:
Accessory serpentine belt routing—4.8L, 5.3L & 6.0L engines
Accessory serpentine belt routing—5.7L engines with A/C
Accessory serpentine belt routing—5.7L engines without A/C
Accessory serpentine belt routing—6.5L Diesel engines
Accessory serpentine belt routing—7.4L engines
Accessory serpentine belt routing—8.1L engines
3helpful
2answers
Serpentine belt diagram
The serpentine belt routing should be labeled on your radiator shroud. Look around the engine compartment like the hood or radiator fram suport and there should be a label with the the belt routing.
Good luck and hope this helps
51helpful
5answers
Serpentine belt replacement
2.0L Engines
See Figures 11, 12 and 13
The accessory drive belt for 2.0L engines has no provision for manual belt adjustment, since these engines use an automatic belt tensioner. Drive belt slack is taken up by the automatic tensioner.
Movement of the automatic tensioner assembly during engine operation is not a sign of a malfunctioning tensioner. This movement is the tensioner self-adjusting and is required to maintain constant belt tension.
The belt tensioner has a belt length indicator. If the indicator marks are not between the MIN and MAX marks, the belt must be replaced.
0900c1528008d836.jpgFig. 11: Drive belt routing-2.0L SOHC engine with A/C 0900c1528008d837.jpgFig. 12: Drive belt routing-2.0L SOHC engine without A/C 0900c1528008d838.jpgFig. 13: Drive belt routing-2.0L DOHC engine
Top Mazda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mazda Expert? Answer questions, earn points and help others
