Minolta C350 Printer Logo
A
Anonymous Posted on Sep 03, 2013
Duplex bizhub driver
How to print double sided documents
Norman Weimar
Level 3:
  • Minolta Master 7,035 Answers
  • Posted on Jan 25, 2015
Norman Weimar
Minolta Master
Level 3:
Answers
7035
Questions
Helped
1913678
Points
11960
In Printer Perfrances select back to back or double sided make sure you also select Binding Left for printing second side and you don have to flip the paper over or Top Binding like a lesson top lecture note book
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1 Related Answer
Anonymous
  • 1847 Answers
  • Posted on Sep 09, 2008
SOURCE: Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Print double sided
Select your printers properties
Duplex printing
You can print a document onto both side of a page. This comes in handy
when you want to bind multiple-page documents.
1 Click the Layout tab.
2 From the "Double Sides" drop-down list, select "Double-Sided".
Note
The binding orientation can be specified from the "Binding Position"
drop-down list.
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
1helpful
Bizhub 211 double sided printing inactive
It was the same problem. To enable drop down menu open "Device Option" tab where you will see list:
Duplex Non Instaled
Tray2 Not Installed
Tray3 Not Installed
Just double click on "Duplex Not Installed" and it will changes on "Installed" and Double sides drop down menu become active.
1helpful
2answers
How to set a MG5220 printer to do 2-sided copies?
The Canon MG5220 has a built-in auto duplexer and can print 2-sided documents. On a Mac, click print, and in the print dialog box select Duplex Printing & Margins (drop down options below Printer and Presets). Check the Duplex Priting box, and selected the Stapling side. Then click Print. That's it!!
3helpful
2answers
How to get a Canon MG5220 printer to print 2-sided copies
If you have a Canon MG5220 you certainly can print two-sided. I have one and I print two=sided pages. When you bring up your print menu underneath "Orientation" is a small window that likely says "layout". Click that window and you will have various options to choose from; color matching, paper handling, cover page, quality media color options. borderless printing and duplex printing & margin. Choose Duplex & Margin. Once you've clicked that you'll see a check box for duplex printing, click that box. You have other options for for reduced or normal printing (your choice) and then if you're stapling there's options for the side you'd prefer but the point is once you've checked off that box for duplex printing you're set to go.
How do I print double sided? The "Print Type = Double Sided" check box isn't doing it.
the duplexer may not be installed on the driver to chack this:
go to the properties of the driver on your computer
click start
then control panel
then double click printers and faxes
then right click on the konica bizhub driverand click on properties
click the options tab on the driver and under duplex unit make sure the drop down menu says installed
if it shows the duplex unit is installed then check the application you are using to see if it has duplex settings some applications have there own settings for document properties that you can change to duplex and the application settings will take over no matter what you tell the driver to do and some applitions will not allow you to make changes so duplexing may not be allowed
2helpful
How do I print a two page, single sided, document onto a one page, double sided, document?
go printer driver properties device setting and enable duplexer.
secondly,when u sent print to printer befor sending printing go on properties page and select "duplex"
3helpful
2answers
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
6helpful
Double sided printing
Firstly ensure that the duplex unit is installed by going to start - Settings- Printers and faxes.
Then right click your printer and select properties. Select the last tab at the end of the properties screen which reads "Option"
Then under the options where you see the Duplex unit option select "Installed" from the drop down menu.Click Apply and OK
Alternately you can insert the ip address of the printer and select the gather option information...
Now for double-sided/duplex printing
1. Open the document you want to print eg: MS Word
2. Click on the "file" menu select "Print"
3. Then Select the printer from the drop down menu
4. Click on the "properties" box next to the printer you selected
5. In the first screen on the "Setup" tab find the Binding option and select at the Print type "DOUBLE SIDED"
6. Click apply and this will enable double sided printing.
7. you can leave the binding position on "Auto"
Hope this helps
Regards
Rene Fernandes
2answers
Double side to single copy w/o paper feeder
Try this.
Set the copy for duplex.
Put the drivers license on the glass.
press the start button.
Turn drivers license over.
Press the start button.
Should copy on both sides of sheet.
If you copier has a booklet setting on it in the duplex. Page the front and back of the drivers license will appear on the same side of the page as well.
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
