Have you read by advice on how to diagnose this problem? Click on the following link:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
If you HAVE water entering the wash tub, first verify that you do not have a siphoning condition. This is where the drain line does not have the proper air gap to drain properly and creates a vacuum on the
drain line. This will cause drain problems and may prevent the washer from filling all the way. Or, you may have trouble maintaining the water level. When you stated you had water leaking, is this a visible leak? Or, do you have water slowly draining from the tub? Double check your drain line to be sure.
Next, check the drain pump to ensure it is not clogged or obstructed which minimizes drain flow. Also, make sure the pump is running. Remove the access cover and clean out the pump reservoir. In addition, check the drain line from the bottom of the wash tub to the inlet side of the
drain pump. I have personally found small articles of clothing stuck in this line, preventing drain flow.
Read through the link thoroughly. If you require
additional assistance, please let me know before rating the solution. I hope this helps you.
