The system has to see a wide range of conditions before a smog test can be done. On most brands you have to drive at least 50 miles, at various speeds including stop and go, let it idle for 5 - 10 minutes, and run at freeway speed for at least 25 miles. It also has to reach normal operating temp of 195 degrees.
The steam function and the expresso use the same elements to create the steam but the valves will direct the steam to the expresso unit or the steam arm. Most likely you have a faulty valve. In most cases the valve will not open until the pressure gets to the right level. If you are just getting hot water out of the steam arm instead of steam via the expresso unit it most likely means that the valve is faulty. The valves can be replaced but is not easy. You will need to have the unit serviced or you could try to replace the valves. Make sure the flow meter is working before you replace the valves. You can check the operation of the flow meter by running the hot water cycle and making sure that you get the right amount of hot water. Good luck!
Your batery is dead they don't like long period of staying discharging (If you 100% shure that your Nikon is working) The time of charge dosen't matter.
