It's getting gas to the carb. but the sparkplug is dry.so it's getting thru the regulator and coming out the fuel line to the carb.but,the sparkplugs are dry.and i checked for fire and theres good blue spark.
If you have spark, compression, and fuel to the carb but not at the plug. You have a clogged carb. Try starting with starting fluid, if it fires briefly, your carb needs to be removed and cleaned.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
SOURCE: no spark
hi is this a point less ignition or electronic? check that your ground wire from ign. coil is not grounded causing no start.( last ign coil shot) good luck.
SOURCE: gas not getting to carb. Blew out all lines gas, new gas filter
fuel line cracked in shroud just fixed one just like it check fuel line from filter to carb
SOURCE: I have a Craftsman mower LT1000 riding mower 17
Need to pull tour carb bowl and clean out, make sure while you have off check you float and make sure it moves free,I hope this helps you and thanks,
SOURCE: john deere 425 mower won't start
The ignition switch module is likely to be the problem,they seem to quit for no good reason.The safety relays and fuses are built into the board that comes with the switch and will most likely fix your problem.
SOURCE: Mower wont start.
I have a 927 series rider and just put a new battery,and spark plug.Has spark and still wont start. What else can I try?
