Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
http://www.inkjet411.com
SOURCE: printing problems
Unfortunately there is little you can do to troubleshoot hardware malfunctions like this you describe. Especially on inkjet printers. You would be better off getting a replacement printer.
Make sure you take the plastic guards off the cartridges, other than that there really isn't much more you can do.
SOURCE: I have an HP Deskjet 6122. Cannot get documents
Your printer needs some manual servicing.
It's advised that you leave it for a qualified technician to do that.
From the problem you described, the encoder sensor may be causing this problem.
