05 equnox sharp turn noise
I forgot to ask if the noise was front or rear and stationary or moving so I will cover both.
If the noise is while the truck is stationary and the noise is from the front I would have to say the power steering pump. I have been changing several lately for similar concerns.
As far as the rear if the noise happens while making sharp turns and makes a whirring/growling noise while in motion its the rear differntial. What you can do yourself to be sure is find an open lot and drive in rather tight circles for about a minute, then noise should stop. This action flushes the clutch disks and stops the noise. If the noise goes away you will need to do a rear diff flush.
The fluid is very expensive so be sure this is your problem first.
In order to do the flush drive in tight circles for 5 minutes in each direction and then drain and fill the rear diff with the new Versatrak fluid.
Good Luck
