Note error codes displayed - if camera shuts off
immediately ; if tape is inserted ? put camera to
your ear and apply power : if more than one motor
sounds ( or sounds ' jerky ' ) your tape may be
damaged - no user serviceable options left ;
if no tape is inserted ? check with stacy
sample at jvc factory service in houston ,
texas - for possible warranty updates .
The battery is very likely BAD (has high internal resistance)! Can you take the battery OUT, and run with ONLY the charge cable attached? Does that make any difference in performance?
Please check your drivers are on the PC for your camera so the PC can see your camera connect to it, when you plug your camera into the PC USB slot you should see a message come up near the bottom right-hand corner telling you your connection has been made, if not then your camera driver is either missing or damaged, go to camera makers site and download driver again. Good luck.
JVC will repair for free some camcorder models that suffer from the LENS CAP error. The repairs are free until OCTOBER 1, 2007 only so hurry up and see if your model is listed at http://www.jvcservice.com/service/custnoticecamcorder.asp?ReqType=CCD
i want this model motor
