Hey Guys, Problem with my Sceptre X7g monitor. It just stopped coming on & now just flashes blue, red, blue, red, blue, red stops and then cycles through it again. Have tried it on different computers and have tried other monitors. They will work, but the Sceptre doesn't work on anything. Not sure what it could be????
I fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Here is what I got from customer service for this issue:
Dear Customer,
While the monitor is doing that, unplug the power plug, and unplug the
vga cord from the monitor’s side. Make sure the computer is on and not
in screen saver mode or power saving mode. Hotplug the VGA cord into
the monitor, then plug in the power cord and turn on the monitor. That
should solve the problem.
If not please try this alternative method. While the monitor is doing
that, unplug the power plug, and unplug the vga cord from the monitor’s
side. Make sure the computer is on and not in screen saver mode or
power saving mode. Hotplug the VGA cord into the monitor, then press
and hold power button for 3 seconds and keep holding it while you plug
the power plug in. Do not release the power button until you see the
power LED light flash once. Afterwards you should be able to use the
monitor normally. Thanks
Per Sceptre-
Worked for me thanks for your help!!
Having the same thing happen to me.
I've tried their "troubleshooting" and nothing worked.
I ended up throwing the monitor away.
Samething let me know
Add one more to the list. I have the same problem and have also tried it on three other computers.
Sceptre X7 Monitor quit working and now has a light flashing alternating blue then red. Any suggestions? Thank you.
yea i have the same issue, i turn it on and it just flashes red and blue.
then when i turn on my computer it just blinks blue and nothing happens
I have the exact same problem. It almost seems as if it suddenly over heated or some thing.
Is there a reset or some thing to get this thing up and running again?
The monitor is barely a year old.
I have the exact same problem and I tried the power down, (Had to unplug it) and repower it. Still to no avail. It flashes like it wants to display something but always stays black. I rebooted the computer to no avail. It shows the boot screen, but turns black when starting the windows xp pro boot process. The monitor is less than 9 months old.
Sorry, should have posted it here.
I have the same problem. I tried doing what the best solution said and it didn't work. Tried it like 3 times.
Sames as the rest... Bottom line - Its a crappy monitor...period!
on light come on but the on lights don't no screen action
