Sony Vaio Pcg-7133l Vgn-nr498e Fully Loaded Win 7 - Office 10 - Fast Shipping Logo
A
Anonymous Posted on Sep 02, 2013
Pcg 7133L disable touchpad - Sony Vaio Pcg-7133l Vgn-nr498e Fully Loaded Win 7 - Office 10 - Fast Shipping
1 Related Answer
Anonymous
  • 114 Answers
  • Posted on Nov 02, 2009
SOURCE: HOW TO DISABLE THE TOUCHPAD ON A PCG-K33 SONY VAIO
Check this document for help.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C165781&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=142429048&stateId=0%200%20142425829
Vaio PCG-7133L. Can it be turned on without a battery?
Not unless it is plugged in with a charger. That only works if the power supply is routed through the battery. It should work though.
Sony vaio PCG-391M touch pad freezing
If you have a Sony Notebook Setup utility under Start Menu, All Programs, Vaio folder, it can have a Touchpad tab where you can disable the touchpad.
Sony Vaio laptop (PCG-61317L) once I start browsing the internet, the screen freezes and the mouse cursor disappears from screen. When I don't browse the internet, it sometimes does the same thing
The reason this is happening is that as you are typing; you're resting some weight on the thin plastic above the touchpad...which then makes contact and registers a 'click'; thus moving your cursor around. Or you're brushing your thumb against it when hitting the space key.
Some laptops are more susceptible to this than others. Some more modern laptops come with a button to turn the touchpad off to solve this very problem.
The only thing you can do about this is to disable the touchpad through the touchpad driver (down by the clock, usually) and use a mouse instead. Depending on how you use your laptop, this will be more or less inconvenient- if your laptop never leaves the desk; disable the touchpad and use a mouse...no problem. If you go mobile a lot, you'll have to enable and disable the touchpad all the time.
The other thing you can do is adapt your typing style so you don't put any weight on anything but the key you're pressing. This is quite difficult and uncomfortable, and is not recommended for long sessions.
1helpful
How to enable the scroll on touchpad on my sony vaio laptop PCG-61411l
Go into your touchpad software and set the settings. Click Start/Control Panel and look for Mouse or Touchpad.
3helpful
2answers
I can not disable touchpad of INSPIRON 1545 of DELL Computers There is no option for disabling touch pad in the MOUSE option of Control Panel
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
1helpful
Trying to re-enable the touchpad on the sony vaio vgn-fw200
I recommend you to check the touchpad settings and also reinstall touchpad drivers if the issue persists.
Visit the below link for more information:
http://notebook-solutions.blogspot.com/2010/09/how-to-resolve-laptop-touchpad-not.html
Any way to turn off touchpad when typing ,etc
« Free Up Windows 7 RAM - Memory Cleaner Enable Administrator Account In Windows 7 » Auto Disable Mouse Touchpad When Typing By Nakodari on Nov 25 2009 28 Comments
It is a common annoyances with netbooks and laptops which lack the disable touchpad button. Most blogs out there are covering a single method to disable the touchpad, i.e, go to Control Panel > Mouse Properties and then disable the touchpad from there.
The above method is not suitable for those who need to disable the touchpad frequently for short periods of time. Who in his/her right mind would navigate back and forth just to enable/disable touchpad? This could be quite a hectic process.
TouchFreeze is a brilliant little app that solves this problem. It disables the touchpad temporarily the moment a keystroke is pressed. In layman's term, it disables the touchpad automatically when you are typing and enables it back when the typing is stopped.
It will sit silently in the system tray without disturbing any of your work. Just start typing and don't worry about the touchpad any more.
touchfreeze.pngI prefer using this app even though my notebook has a disable touchpad button. Please note that this app might not work with certain laptops, but should work with most netbooks and laptops that lack the disable touchpad button.
Download TouchFreeze
http://code.google.com/p/touchfreeze/
How can I get in touch with Sony about my Sony Laptop 00146-526-154-990 model PCG-7133L
Here is your info
Priority Service: 239-768-7669
Toll Free Service: 1-888-476-6972
Hours:
  • English: 24 hours x 7 days a week
  • Español: 8:00am-1:00am ET x 7 days a week
HOW TO DISABLE THE TOUCHPAD ON A PCG-K33 SONY VAIO LAPTOP?
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
