No oil in the oil filter period?? Does the opening of the oil filter face down.. like the oil will drain out if sitting still?
..You need to talk to a qualified professional.. this could be very serious or SOP..
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
when the alarm goes off is the engine getting hot, try running it in gear under load while tied up and with the engine cover off see how hot it gets and if the water i circulating all the time , might have cooling problem !
try priming the fuel bulb when it boggs down and if it speeds up then replace fuel pump diaphrams etc and clean carbs and balance to start a fresh ! fuel tank clean ?
The correct mixture is 50:1, or 1 pint per 6 gallon tank. Use quality brand-name outboard TCW-II or better oil(Bombardier or Mercury eg.) to eliminate the oil as a problem.
Check your plugs for fouling. If using perma-gap / surface-gap type plugs, switch to the L77JC4 type, especially for long idling or slow speed operation. For extended high speed operation, the surface gap plugs are recommended.
