SOURCE: I have the same problem Panasonic Plasma TV wont come.
Alot of times capacitors on the power supply circuit board will go bad. They will bulge/dome or dry up which will cause this problem. Bad caps dont hold a charge, which is needed to maintain a voltage. The circuit board is two sided which makes replacing the caps difficult, and the board can be damaged and have to be replaced. Taking it to a repair shop may be cheeper and safer then doing it yourself. Having two-six caps replaced is a lot cheeper then a new board.
SOURCE: Panasonic plasma TV model TH-42PD60U won't turn on
I had this problem in 2007 / 2008 here is what happened to me.
Jan 09, 2008 - I also have brought the unit to the authorized Panasonic repair facility and the problem is a failure in the P-board which is the power supply board. The P-board needs to be replaced. The repair will cost $475 plus tax. $250 is for labor. The unit was nop more than two months out of warranty. This does not speak well for Panasonic. I have been researching the problem and it looks like this has happened to many of the Panasonic plasma TVs.
Jun 14, 2008 - As an update to my problem with the failed P board. Contacted Panasonic Service and talked to a customer service representative. I told them how I have purchased many Panasonic products and how unhappy I was with the failure of the product. They proposed paying the labor cost of $250 and I would pay for the part. I just hope it does not happen again.
