Nikon Coolpix L23 10MP Black Digital Camera Logo
c s verma Posted on Sep 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reset date want to change the date??
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Nikon Master 102,366 Answers
  • Posted on Sep 03, 2013
Nikon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10429739
Points
622693
Press the MENU button, select Setup, select "Timezone and date," then select "Date and time."
2helpful
2answers
Why does the date on my seiko sne881 change at 12 noon?
probably because you have it set to 12 pm midnight and not 12 noon so at 12 noon it is actually midnight when the date will change
reset the time of the day to am or pm and any pm settings will change the date at 12 midnight.
How do i reset the date and time without replacing rtc
You can do it from within the BIOS settings if you want. Choose F2 at startup and that will take you into startup. There you can change the date and time. If you are in Windows and want to change the time and date, simply left click on the time indicator on the taskbar and when the window pops up, choose change date and time. Make sure of the corrected date is in fact correct or your computer will not function correctly.
How do iturn the service light of on a sabb 93 2006
on the SID press customise then select system settings then service info and select reset service info. If the option to reset is not there you will need to change the date to a date beyond the 'Days to service', reset option will then appear. when reset, return date to correct setting. (to change date press and hold the info select button when the date is displayed.
Changing the battery resets my date. is there another battery
your camera doesn't have internal battery so everytime you change the battery it will ask you to set the date...
4helpful
Can't find my manual and need to reset the date and time
if system DK series must set at port "00"
#402 to check the port number with displayed phone
#651 DDMMYY - for date
#652 HHMMSS - for time
#653 to change the day
2helpful
Unable to change today's date on new Samsung SHG-D980
To change the date select:
menu, settings, time and date.
Drag down the screen until you reach the Date box.
press once, press a second time.
enter the date and press OK
save and exit
hope this works, it worked for me and I had exactly the same problem.
3answers
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
4helpful
Samsung S630 date gets reset while changing the batteries
It is really NORMAL that the date will be reset to the Manufacturer's date whenever you are changing batteries.
For you not to keep on changing the date and time of your camera, use Rechargeable batteries for a longer battery life span but make sure that you will be setting the battery type of your camera for the Rechargeable ones.
To set the correct battery type.
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see BATTERY TYPE
- Select ALKALINE if you're using NON-RECHARGEABLE
- Select Ni-MH if you're using RECHARGEABLE
- Press on OK/MENU button for changes to be saved
Turn off camera after the settings
have been changed to refresh the camera.
4helpful
Trouble with setting date.
hello,to set the date:
push and hold the mode button for 3 seconds,then push the mode 1 time it will take you to the time,press the st/stop 3x's to reach the month,use the lap/reset button to change,4x's to reach the date,use the lap/reset button to change,5x's changes the day of the week,use the lap/reset button to change.when yor done push the mode button to set.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
