? 7:51 www.youtube.com/watch?v=yxfDICZ0Ses Apr 21, 2010 - Uploaded by applianceassistant
Washer Agitator Repair Agitator Not Working Repair ... of a whirlpool built washer, manufactured under the appliance brandsMaytag, Amana, ... How To Repair Washing Machine Agitator -Remove And Replace Agitator Dogs ..
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This wil require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
The agitator coupling beneath the agitator needs replacing. It is stripped. Pull hard on the agitator to pull it off the shaft to expose the coupling. Remove the coupling and replace it with a new one. Replace the agitator. If the agitator is hard to remove,use a old leather belt under the agitator to pull up on. Watch your nose when it comes loose.
the agitator shaft to see if it is working properly. This will require a
work properly, the problem is in the transmission. Hope this helps.
Hi, Do you know if the lower half of the agitator is working? THere is a dog kit that might need replaced in the agitator to get the top half to work. If neither half agitates, there is probably a transmission issue. Start the washer with no laundry in it and see if either sections of the agitator work.
I hope this helps you.
Check the agitator by turning it back and forth. It should work like a
ratchet (turns one way, locks the other way).If you're able to turn it
in both directions, the agitator dogs are worn and need to be replaced.
To do this remove the agitator cap and the bolt that holds down the
agitator. With the bolt out you can remove the top section of the
agitator (auger) where you should see 4 small white or beige plastic
gears (dogs). Replace those and it should be ok.
Thank You For trusting us with your question Please remember to leave a solved rating before you leave!
