SOURCE: engine cut out,would not start again,checked
Gasket seal could have gone but it also could be piston rings has cracked and fell to bottom of engine ??
SOURCE: engine will start and die immediately what is the
If this unit has a Zama carb (or even if it's a Walbro) this will help you alot: http://www.zamacarb.com/tipspage.html
SOURCE: On my Husquvarna 350 chain
The 350 series saw did not have a tube and filter from the oil tank, the filter was a grey plastic insert in the base of the tank, held with a single cross head screw, it can be removed without removing the fuel tank, it can be seen on the sprocket side between the crankcase and fuel tank, the workshop manual is generic, and refers to the 345/351/353 which does have a pipe and filter.
