1) adjust the REED switch see the diagram attached. Clean it+ 2)test for open or faulty 3) tight the connector very well.
2) tight the upper and lower connectors very well and clean it.
3) inside from console tight the ribbon cable and clean it
God bless you
Testimonial: "Thank you Mr. Ernesto Cuadra, I can't wait to try this tip out."
SOURCE: I have a T54HR horizon treadmill. The problem is
best if you see the local retailer where you bought the treadmill. Obviously the switch, whick is a magnetic disc is not activating the sensor in the control panel and need to be looked at.
SOURCE: Horizon Treadmill T5.1. A sudden vibration and
To find a specific bearing that has gone bad in a treadmill you can use a long handled screwdriver and touch it to a non-moving portion of the rollers and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding noise of the bad bearing with be amplified by the screwdriver.
Normally the button and reset is in FRONT from the machine is you stand from the machine in the lower part, Is RED and at the side is reset button.
2) Test the fuse inside see the block diagram , test and replace.
3) Test the power cord for open, break
4) test the outlet wall, reset the breaker from you house, DO not use any extension cord. and proof again.
5) If you can NOT resolve the problem, you must call to the service tech,.maybe you have problem with some component, inside capacitor, transformer in the power supply.
God bless you
