SOURCE: lanier 5645 has a sc542 error code
this is a problem with the thermistors and will need a technician to come out and fix it for you, the part #'s are aw100052 and aw100053 for the thermistors but you have to enter service mode to clear and reset the code.
if this answers your query please rate my answer accordingly
Regards
SOURCE: LANIER LD245 SHOWS FUNCTIONAL PROBLEM SC542
This is a fuser temperature control error code. Could be as easy as resetting the code and rebooting or it could require parts such as a thermistor, thermofuse, heat lamps. Typically though its the thermistors, the sensor that reads the temperature from the heat roller surface.
SOURCE: lanier model 5627,fault code SC542 upon power up
try this:
1. Press the clear mode key (yellow key)
2. Use the keypad to enter "107"
3. Old down clear/stop for at least 3 secunds. (red key)
4. Enter the service mode.
5. Exit all the way and turn off.
6. Turn ON
And thats it
SOURCE: lanier model 5627 with fault code sc542 upon power
LOL I think I already gave you a solution
try this:
6. Turn ON
And thats it
SOURCE: LANIER 5637 FAULT CODE SC542 UPON POWER UP
You have a Fuser Temperature warm-up error, Hot roller warm-up error.
Verify the heater lamps, thermistor and thermofuse continuity.
Enter in the SP mode, turn OFF the main switch, unplug the machine, wait 10 seconds,
plug in and turn ON the copier.
If you need to reset the fuser, Enter SP 5-810 (SC code reset) and
select "1". Then simultaneously press the Original Type key and the OK (or
R/#) key. (There is no need to turn the main switch off and on.).
