SOURCE: i need a driver for
Be sure that your USB is in the correct USB mode. Select Settings'>'Advanced Settings'>'USB Mode'> and toggle to 'USB Device mode'. You should see two devices on your system from the Coby 7024. Only one is readable but it is the one with your data.
SOURCE: I have forgotten my wireless
Hi!
In order for you to remove the password, you need to reset your wireless router. You didn't mention what brand and model of your router, but anyway all routers have a "reset button" just look for it on your router. It is usually found at the back of the router and it is very small, you need a pin or anything long and thin to insert into it in order to push it for about 10 seconds.
Thanks for using fixya!
SOURCE: I have a coby Kyros
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the MID7015******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. .
Step 9- Press the Menu" button to select "Yes- delete all user data".
Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
SOURCE: I forgot my unlock code for my Coby Kyros... how
i NEED Help .. I Have A Coby Kyros MID8120 And I Got Locked Out .. I Have Been Looking Around For Help But Nothing .. If Anyone Knows .. PLEEEEAAASEEEEEEEEEEEE HELP ME .
:c
SOURCE: forgot unlock patter on a coby kyros model MID8042, how can I rest it
i forgot my unlock partern on my coby kyros mid8042
