Uniden 5.8GHz Dual Cordless Phone Logo
Posted on Apr 13, 2009
Static interference on Uniden 5.8Ghz phone
We recently bought a Uniden 8955 5.8Ghz cordless phone and the reception is truly terrible. Even messages on the answering machine are indecipherable. We have tried turning off every appliance in the house, and the statc is always there. Is it just a poor product?
  • Anonymous May 15, 2009
    interference on wireless networks, dropping service within 15 - 20 feet of base.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1018
Points
I have a uniden 5.8 ghz cordeless and thought it was a piece of junk as well. I had static or lapse of audio near the router, the kitchen sink, the microwave (even when off) and in the doorway. I switched the frequency on the router and changed the channels on the phones all with no luck. Short of steering clear of my entire downstairs nothing worked.
Just about ready to buy a new phone and hit up google. Saw a posting that said to keep the base away from even the tv. . .hmmm this is exactly where mine was located. So I swapped the digital answering machine base and moved it downstairs and put the additional base near my flat screen. Guess what? Problem SOLVED! I still cannot believe it.
Hope this helps
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 15, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1421
Points
My phone will not get a phone signal, how do i reset.
How do I turn off my ringer on my Uniden 5,8ghz expandable cordless phone system
Since you declined to specify the model of your Uniden phone, I can only direct you to select it from the list beginning at
http://www.uniden.com/scat/cordlessphones_mnl
to download a copy of the manual.
Cordless phone has volume problems with DSL
For starters that dsl modem should not be filtered.
You should place the splitter directly into the wall jack and place the filter on the side used for the phone. The side feeding the dsl line should not be filtered.
The filter serves 2 purposes. 1 it reduces data noise interference onto the voice line. 2 it prevents dsl interference from voice such as picking up and hanging up the receiver.
1helpful
Extra Static on the phone recently
Try and position the base away from any sources of interference. The most common interference is caused by wifi or wireless routers and microwave ovens. Both these operate on similar frequencies well in your case a harmonic of anyways. If the antenna is adjustable on the base try and tweak it alittle and make sure the base is in the horizontal position. Hope these hints help.
2helpful
Constant static and interference
VTech products are generally poorly designed and manufactured. You can probably notice the FCC Warnings on the device that say that you must accept all interference that you may recieve while in use. Go out, splurge a little, and find a telephone made by a well known company like Panasonic, Sony, etc.
Strong static when I'm on the phone
Try changing channels to find one with better reception. If you can't find a clear channel, try plugging a corded phone into the same jack and see if you get better reception. If you are getting static on your corded phones too, call the phone company to have them check the lines. Don't forget that fluorescent lights, vacuum cleaners, and other electric devices with an electromagnet (light ballast, electric motors, etc...) will create interference.
1helpful
We need a manual for cordless phones - lost ours
Here is a link to the GE website with manuals. I found 5922 EE1 and EE2. I wasn't able to find FE2, but I bet that one of the 5922 manuals will probably help...
http://www.home-electronics.net/ge/pc/user-manuals.asp
Interference on recorded messages.
"I" only charge a simple membership fee of $19.95 to share my "PREMIUM ASSITANCE PLAN" success. I am so sorry that I wasted your time, and my time, for a simple question. Lessons to you in the future- don't expext anything for free. My problem is solved, without any help from your solution, that I never got because of money issues. I didn't use any help topics or pay for them, so I am money ahead! So much for my warranty, right? All I did to fix this problem was......?
Sincerely, the problem solver,
Mike
GE Dect 6.0 Cordless - Loud Static
question is are you running a pc and router/ modem on the same land line
if so you will need the line filters to the phone base
the computer data is transferred by the same land line and there is every possibility that the different frequencies is what is causing the static
reference from a uniden trouble shooter ( will be common as the phones use the same medium)
lots of noise or static on the line === possible solutions --check for interference from appliances ( microwave , tv etc ) or wireless devices ( baby monitors wifi equipment etc)
move the handset base away from the source
if you have any device that uses the phone line , add a DSL or telephone line filter to the system
it is possible from the times you state that the interference could be coming form a neighbour or further down the line so the filter may be the option
available from phone shops or places like JAYCAR
2answers
Model 27851GE1-B
My Cordless set always gives an indication as low battery. Its pretty now one. What is the check list to correct this problem and how can I fix it?
2answers
Background static
1. How old are you phone lines in the house?  Check the "main" terminal connections.  Clean and reconnect.  (Make note how the wires are connected).
2. The power transformers for the phones maybe you trouble also. Unplug all except the main unit.   Check each transfer one at a time. Do you have static?  One or more may be your problem.  Replace the bad ones if needed.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
