Culligan Under Sink Water Filter Logo
Posted on Apr 13, 2009
Have a kent r/o system dont know how to hook it up is there any way someone can help
  • Anonymous Apr 20, 2009
    I have a Culligan under sink ser # Ac 10094672. I replace the filters now there is very little water going to the resevoir. Is there a proceedure for starting this baby back up.
Anonymous
Level 1:
  • Contributor 13 Answers
  • Posted on Apr 28, 2009
Anonymous
Contributor
Level 1:
Answers
13
Questions
0
Helped
15186
Points
41
Make sure that all valves are in the open position.
Try to recharge the water storage tank. Here are the steps to follow.
* In General: When any type shut-off valve handle is positioned so that it is parallel or in line with the tubing that enters the valve, valve is OPEN. When handle is turned perpendicular to tubing that enters valve, valve is CLOSED.
Necessary Supplies:
1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.)
2) Bicycle tire pump for standard type bike tire valve
To recharge RO system tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).*
2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side.
3) Remove stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure)
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this
procedure.
6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient)
8) Turn off RO faucet.
9) Replace cap on valve stem and reposition tank in upright position.
10) Open cold water feed valve.*
11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
2answers
I want to reassemble the filter of kent ROflow diagram kent ro
Try this link it should help you:
http://www.kent.co.in/pdf/Kent_Grand.pdf
I have simon ? dont know which model it was installed in 1991/1993.. anyway someone removed the wiring to the phone jack.. last night .. how can i get a diagram and instructions on how to rehook up my...
If you had a 8 pin jack (RJ31X) hook you ring and tip to #4 and #5. You can also plug a regular phone cord directly into the unit ito the left hand outlet on the board.
Top Culligan Tools & Hardware - Others Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
