SOURCE: tv wont turn on
That same thing just happened to my t.v. The repair person will be here on 10/10/06. I will let you know what they say.
SOURCE: Check fan number 2
greetings from belize let me start by saying that these modern computerize sets always have pop up error some times the microchip act up probably your eepromor microchip needs to be reset or replace, take it to a tech for a check up.NB,be care full opening up the back of a tv touching components, a tv store very high voltage that can be very letal.leave the set to a qualified tech.this job could cost about $100.00 good luck.
SOURCE: Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
SOURCE: tv turns on and turns off after 5 seconds
jim if know how to soldering iron ,resolder your tv especially the power supply
SOURCE: Element FLX-2611B won't turn on. The red light is not lit
Just because fuses are intact does not mean it is not damaged. Sometimes a small spike of power does not blow a fuse but damages Transformer windings Before the fuse! If there are no lights picture or sound think powersupply transformer primary.
