Compaq iPAQ PA-2 MP3 Player Logo
Posted on Apr 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does a compaq ipaq mp3 player have a internal memory without using a memory card?
Arjun Komath
Level 3:
  • Master 1,170 Answers
  • Posted on Apr 13, 2009
Arjun Komath
Master
Level 3:
Answers
1170
Questions
8
Helped
439703
Points
3355
Yes.
It got an inbuilt memory of 64 MB and it got expansion slot to expand the memory.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Just bought a mini clip mp3 player without internal memory. Put in a 2Gb Micro SD card. Computer will play music from device but unable to play music through the mp3 player itself.
browse through the mp3 player setting very well and you will sure find an option to link the music on your SD card to your player.
take care
1helpful
Can an 8GB microSDHC card be used in my Sansa Fuze 4GB mp3 player
Actually, it sounds as if the card is working. The more you have on the card, the more free internal memory you'll need so it can build its media database. Remove the card, then delete some files from the internal memory to free up space. Then reinsert the card.
1helpful
Clearing internal memory
Remove your external card if you have one....Then try plugging ur device into ur computer using windows 7 then your going to have a pop up like if you pluged a storage card into ur card reader....click open folder then youll see all you internal music...right click and start deleteing..If you want to format go to my computer find ur device right click and on the list and youll find format just click it and it will format ur internal memory...or insert ur card and do the same
My mp3 player will not sync to my computer
maybe the memory of your mp3 player is broken.i also have same problem like u but i manage to solve it because my mp3 player has two memory,one for internal and the other one is for memory card.my internal memory cannot be recognise by my computer but my memory that are using memory card can be recognise....so,i prefer u to buy new...sorry..
Compaq iPAQ PA-2
I have the same situation. Although it would have been a good .mp3 player to give to my daughter, I do not think it worth my (or your) time when they have higher storage and smaller bodies for cheap now days.
If you're hell-bent on making it work on those new OS's then your best shot is downloading RioPort Audio Manager 3.3 (or later) because Windows Media dropped it's driver support after version 7 (it's version 11, now). RioPort is what I used before I got a hold of iTunes.
Good Luck!
2answers
Memory card question
It should read the songs automatically. Once you have inserted the card with MP3 Format or WMA formatted songs it should read it.
Sync to internal and external memory without duplicates
Hi try to go MY COMPUTER then go in the the drive check the folder it should have the micro sD folder from there you can just take the song and put them in the folder you want this is the other way i know how to put music in hope it helps.
Sync to player and memory card without duplicates
I got this from:http://www.livedigitally.com/2005/06/27/sandisk-sansa-e130-the-micro-version-of-the-ipod-mini/ Create two playlists with names such as 1. SANSA Internal and 2. SANSA 2GB (assuming your SD card is 2gb). Load songs into each playlist. Edit the sync properties for each drive to only sycn to those playlists. Sync!
Ipaq won't recognise sd cards help!!
did you install the following: "iPAQ H3970/H3975 SD Card Driver Updates version 1.1 (27 Oct 03)" SP25681 - Resolves performance issues with SD memory card. - Resolves undetected SD memory card. - Resolves lockups due to SD memory card.
Top Compaq Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Compaq Audio Player and Recorder Expert? Answer questions, earn points and help others
