SOURCE: Sony CS5 Wont turn on
the cover switch is probably not fully made.
Ensure that the cover tangs are pushing the pin
on the miniswitches.
Try putting slight pressure on the fan or lamp cover to see if the lamp/cover light
stops flashing.
you will need to do a restart on the PJ to check this out
SOURCE: power up
Hi mick1907
Take out your lamp and check for any irregularity like marks or discolouration.
If there is no visible damage - put back the lamp and take of the top cover - start the Projector and check if all your fans are running - that is if the machine starts at all.
If the unit doesn't start up at all you will have to replace the Mainboard.
SOURCE: Lamp cover light flashes even with new lamp
Look closely by the cover there is a small sensor there, could be a pice of dirt and door not completely closing get a cleanpaint brush or little brush and clean area..Good Luck
SOURCE: sony vpl-hs20 cineza projector- reset lamp counter
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't
when the bulb dies, but when a bulb has lost 10% of its brightness - so
you might well be able to reset the timer and get much more use from
the bulb - the image just wont be as bright.
SOURCE: LMP-H150 reset hours on sony cineza VPL-HS2
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS2
