I believe I have the same Ridgeway tent - over 20 years old. Red-, Blue- and Green-labeled poles. Best setup will require at least 2 persons. Here is a quick guide to setup:
1. First, stake the tent floor down making sure it is taut.
2. Center poles are labeled with Blue dots. There are 3 separate poles that fit through the center channel - 1 straight pole with 'male' connectors on each end (this will be in the middle), and 2 poles with curved 'female' ends. The curved ends need to slip through the center loops (there's a 'hook' to hold the loop). The center upright poles consist of a bottom pole (which should have a cap on one end and an adjustable ring on the other) and a 2-piece snap pole (with grooves on one end). Make sure to slip the pole with the grooves through the adjust ring (this will allow adjusting the height of the center of the tent). There are also 2 strings at the center of the tent about a foot above the ground. Tie these strings around the upright center pole to ensure that the center upright pole doesn't separate too far from the tent.
3. Poles with Red dots are for the ends of the tent. There is a curved 2-piece snap pole that slips through the end channel. Then, you have a 3-piece straight snap pole that attaches to each side of the curved pole. The bottom end of the straight pole should be placed about a 1.5 feet from the bottom of the center pole (at about a 45-degree angle). The door ends are essentially 'leaning' outward from the center.
4. Poles with Green dots are for the extended door cover on the large door side. These are 2 snap poles with ends that fit through the grommet holes of the cover.
Photos of erected tent are attached.
We don't use our tent very often, but my son just took it camping and it was a breeze to set up. If you still have the plastic stakes, I would recommend replacing those with metal stakes, as the plastic stakes break easily. Also, you may need to find a rain fly that fits the tent.
