SOURCE: Hi. My Korg X5d shows a sequence of small squares
You need a reprogramming done from the Maker . Contact Authorized Korg Service center . Be away from frauds.
SOURCE: Hi, my korg X5D have
The pitch and modulation wheels are on a separate circuit board, if they both stopped working at the same time, it's likely the connecting cable has dislodged.
Opening an X5(D) is relatively simple and you should be able to simply plug the cable back in. If you're not comfortable doing that, take it to a shop.
SOURCE: how to turn on en
For Combi/Multi patches you can disable control changes for each sound under EDIT 6D but this also switches off other control change instructions (pan, expression, pedal etc.).
Somewhere under GLOBAL settings you should be able to find the modulation wheel Depth setting and set it to 0 which should stop your mod wheel from working but you could achieve the same effect by just keeping the mod wheel pulled all the way down.
Testimonial: "thank you 4 your insrtuction"
