First, you have to loosen the crank pulley center bolt. Best way is with an impact gun-bolt is very tight. If you have to use a breaker bar to loosen the bolt, you will have to devise a way to hold the crankshaft from turning backward while loosening it. One method is to remove the starter and wedge a piece of wood against the flywheel, preventing it from turning, while you are loosening the center bolt.
From the beginning: raise and block the side of car that the front of engine is towards. Remove the wheel and the inner fender splash shield. Remove the belts. Remove negative battery terminal, remove starter. Wedge the flywheel so it won't turn backward. Loosen and remove the center bolt. Some harmonic balancers will slide right off the crankshaft now, some are on very tight, if you can't wiggle it, tap it, and get it to move, then buy an inexpensive harmonic balancer removal puller, just a few bucks, easy to use, will save balancer from trying to hammer it off. All you need is enough room to mount up the puller to the balancer, and get the balancer moving off the crank.
Some engine lay outs there isn't enough room: then you really have to get creative, either lowering engine enough to get to pulley, or raising engine out. But most engines are positioned where the crank pulley can come off easily, with enough room to get the puller on.
The pulley may have a woodruff key in a slot on the crankshaft, and a corresponding notch on the pulley, for proper positioning of the pulley to crank. Don't lose the woodruff key.
SOURCE: BAD HARMONIC BALANCER
To remove the harmonic balancer on my 1992 Pathfinder, I needed to loosen the alternator and power steering belts, remove the cooling fan (4 10 mm nuts), remove the radiator (2 10 mm bolts hold it to the frame, remove top and bottom hose [The drain **** is covered by what appears to be a coolant line], as well as the overflow tube to the reservoir. With a 3/4" impact gun and a 27 mm socket, remove the bolt that retains the alt, ps shieves and the harmonic balancer to the crankshaft. With a large 3 jaw puller, remove the harmonic balancer with the pully sheives as an assembly. I do not recommend attempting the removal without the puller.
To put it back on, you will need a large torque wrench for the crankbolt and a small torque wrench for with a crowsfoot for the fan nuts.
SOURCE: Remove the harmonic balancer without a puller?
You can try simply wiggling the balancer and see if you get lucky. A few taps with a rubber mallet may convince it to come free. Worst case get the kit. You should not need to remove the radiator. Do make sure that you have the engine blocked so you don't lose your timing mark placement.
SOURCE: Mitsubishi Eclipse Harmonic Balancer 3.0L Removal
There is a panel inside the wheel well that you can take off that gives you perfect access to the harmonic balancer. A special tool is required. i had my dad make one because he has access to whatever he needs at the factory. but you can get them at the dealer. i have no clue how much they cost. I can't see any way of doing it without the special tool. after you get the tool its pretty simple to get off. it takes alot of force to break the bolt loose though. i used the handle off my jack as a cheater bar. hope this helps...
