I am don`t use my front camera
[email protected]
Hello there,
The reason the front camera is not working is simple. It is either the front camera is bad, or that the software to read the front camera is corrupt.
First you need to go to the option and select camera, then you check for the front camera to see if it will work from the option, if it does not work. Then it means you either need to replace the camera or you format the phone.
First try to flash the phone by using the appropriate software, that will reset the phone for you and the camera will be able to work.
Hope this was helpful
Goodluck
Elect_Comp
