Check to make sure the flash up switch on the side of the flash (the switch you see where the wires go through when you remove the flash top) is not under the activation rod on the pivot, the pivot is not pushed in, or the activation rod is not broken off. The switch should close when the flash goes up and be open when it is down. A lot of times you see the top contact stuck under the activation rod. Also check the continuity of the two thin switch wires as sometimes they are borken inside by impact
SOURCE: Flash pops up but does not flash
Turning the Flash Off and On: 1. With the camera in any user set, repeatedly press the Flash/ISO button on the lens barrel until the flash cancel icon (a lightning bolt in a circle with a slash through it) is displayed on the control panel and screen. 2. When finished, to return to the default setting, press the Flash/ISO button until AUTO and the lightning bolt icon are displayed on the control panel and no flash icon is displayed on the screen. If it still doesnt help: 1. Check that batteries are fresh. 2. Check that camera hasn't been set for no-flash mode. 3. Give the flash time to charge before pressing shutter.
SOURCE: Flash: PCB Replacement v. New Bulb!?
I just read a few forums about this, and apparently it is a common problem on D50s. The flash pops up with such force that eventually the wiring and/or bracket that pops it up comes loose or breaks, and the camera needs to go in for repair. It probably isn't the bulb.
I'm looking into getting a D80 or better anyway once I have some money saved up, but until then I am using my SB-600. I'd suggest taking it to a repair center if it's still under warranty. If not it will run you around $150-160 to get it fixed, and takes about a month, according to what I read.
Hope this helps!
SOURCE: Nikon D40 will not flash
The lightning bolt icon in viewfinder blinks when flash is not ready, this can happen if flash doesnt pop up all the way, or if flash strobe tube is bad.
SOURCE: can't enable manual white balance and other options on nikon d40?
white balance can only be manually configured on "PSM" modes only, the other modes set the white balance automatically .
SOURCE: My Nikon d40 build in flash not working after fall
I have also had the problem of flash not working on my Nikon D40. I
found out the problem and I made a quick video to help those who
are having this problem. Here's the link to the video: Hope this helps
Nikon Flash Fix
