SOURCE: emerson lc320em2 how do we hook it up to netflix
The Emerson LC320EM2 is not a Smart TV. To display Netflix content, you can connect the TV to your computer via the VGA port on the TV. Then use the TV as your monitor; this may not work with HDCP content. To do this, turn off both the TV and the computer before connecting the devices. Then turn on the TV and set it to the VGA input (PC) before turning on the computer. (Note: you may have to enable the port in the BIOS on some laptops.) If your computer doesn't have a VGA port, try a DVI to VGA adapter. (This may not work with some video cards that only have digital signal output. Look at the port and make sure that the cable/adapter doesn't have more pins than the port.)
Alternatively, get a set top box with Netflix support. (Some Blu-ray players, the Roku box, Apple TV, or the WD Live Hub all have internet connection options and support Netflix. All will support a wired ethernet connection; some models will require a dongle to connect to a wifi network.)
Once you have the set top box, connect the TV to the box via a HDMI cable (purchased separately for most units). Connect to your internet connection and then log into Netflix, These steps will depend on the unit; please add a comment with your source of the Netflix content.
I hope this helps.
(I have an LG Smart TV; it is slow to find the wireless network when started. So expect some wait time before you can sign into Netflix.)
SOURCE: i need remote control code for Emerson 32 in tv
These are the codes for Emerson TV: 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
SOURCE: Emerson LC320EM2 HDTV
If the inverter that supplies power to LED back-lights, the screen will be dark, and sound will be OK. Check it. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.http://electronicshelponline.blogspot.com/
