SOURCE: 97 toyota 4runner factory alarm not allowing to start
lock your doors and close it wait till alarm resets and then unlock door with key and this should take care of you problem
SOURCE: I have a 1995 Toyota
First, read through the tips on the below link and learn how to deactivate the alarm on your Toyota. This tip was posted by me.
http://www.fixya.com/cars/r6746176-set_cancel_theft_deterrent_system_or
If that doesn't solve the problem, then it means the alarm system is not the cause of the problem. But let me know which ever the case may be so that I can direct you further.
Good luck.
The alarm system somehow got activated , this is usually because the battery becomes discharged or disconnected try doing this:
Remove the key from the ignition
disconnect the negative battery terminal
put the key back in and turn to ON
exit the truck and leave door open
reconnect the battery terminal
get in and leave door open, if the alarm horn stays off it should start.
It is not the car horn alarm. It's the alarm preventing the car from starting. This alarm sounds similar to the door dinging when the car doors are open. The Lights and taillights flash for a few minutes then stop.
2000 taurus.. wont turn over. thieft light on. how do i reset it so i can start it?
disconnect the battery for a few minutes and try again.
