Inverter KEB COMBIVERT F5 Logo
Maxwell Ahiagbede Posted on Sep 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My keb combivert f5 ser- no. 02292642/0450840 art-no.12.f5.b1d-3aoa is faulty due to operational error, i want to reprogram it so that it can function very well so please l need a programming manual and how to set the parameters.
mntech1
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
New Friend:
  • Inverter Expert 120 Answers
  • Posted on Jul 10, 2014
mntech1
Inverter Expert
Level 2:
Mentor:
New Friend:
Answers
120
Questions
0
Helped
78108
Points
185
Go to: http://www.kebamerica.com/en/service-downloads/downloads.html
SelectManuals
Frequency inverter
Language - ALL
The click on search.
You will want to look at the manuals under: Frequency Inverters > COMBIVERT F5 > Control Circuits > Basic (51)
1 Related Answer
shahrameazim
shahrameazim
  • Posted on Feb 21, 2014
SOURCE: please i need a programming manual for KEB COMBIVERT F4 INVERTER
My KEB COMBIVERT F4 is faulty due to operational error, i want to reprogramme it so that it can function very well.The details of inverter are :ART-NR F4 C0G-4GV01/, SER NO. 00500101/0398540. You can send it to my e-mail [email protected]. Thanks in anticipation.
How can I reset the error E.OP from my F5 Combivert inverter?
I may miss the point here. If the question is how to clear the error, page 57, item 4.7 Error Messages, of the KEB instruction manual may be of use. https://www.manualslib.com/manual/1293218/Keb-Combivert-F5.html?page=55#manual
Here is information about the error code:
KEB Error "E. OP"
ERROR overpotential (voltage)
1 Voltage in the DC-link cicuit is too high.
Occurs if the DC-link circuit voltage exceeds the permisible value.
Causes:
- poor controller adjustment (overshooting)
- input voltage too high
- interference voltages at the input
- deceleration ramp to short
- braking resistor defective or too small
Given the very technical nature of the KEB, I lean toward referring to the manufacturer's support. There are quite a number of KEB YouTube videos and a number of supporting documentations available on the web. Perhaps the following will be of use if not an entire misdirection: https://www.kebamerica.com/elevator-support/
https://www.kebamerica.com/products/f5-inverter/
tip
KEB COMBIVERT F5 - Standard communications connections
Here is an overview of the the items required to communicate with the KEB COMBIVERT F5.
***X4A and X6B connections require special cable from KEB. This is a 24Vdc connection and will damage your PC/inverter if the proper cables are not used.**
tip
KEB COMBIVERT F5 help
When ever you have a questions about a KEB Combivert inverter, it is best to provide as much information as possible. At a minimum provide the following:
Part# or art-nr
Serial # or ser-nr
Fault codes
Type of machine
Machine manufacture
Problem description
KEB manufactures many different types of F5 inverters and each type has different hardware, software and functionality. With the above information it is easier to provide a better solution to the problem.
F5 KEB inverter nop problem
If using bus communications (Can, ProFi, Mod, ext), there may be a communications command (Software signal) that is not being provided. Hardware and software enable signal required to obtain LS.
Possible that the terminal on the control card is bad due to miss connection or signals outside of the rated value.
What Error COM KEB mean ????i have F5 version
The KEB inverter does not have a "COM" error.
Where is this error being displayed?
Check your inverter baud rate, inverter address, communications cables and device that is being used to communicate.
Sir have a nice day, i have problem about KEB combivert F5 28kva running but after 3-5 minutes have a display error E.OH means over heating blower fan is working condition,pls what the solution of this...
Verify that the cooling fans are operational and that the heatsink is actually hot to the touch.
If the heatsink is not hot to the touch there is perhaps a problem with the temp. sensors in the inverter.
Inverters stops without any error but can buss communicates inverter error!!!
If the inverter is not displaying an error but the CANbus system is showing an error, the problem is with the communications.
Could be a faulty CANbus system, operator in the inverter or possible EMI issue.
15helpful
4answers
F5 keb inverter problem
i have a prblem in the F5 keb combivert it's show Error
E.OC & E.puci & E.Puch could you please advice us with the proper solution
thanks
Top Inverter Electronics - Others Experts
Ngoro
john h
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
