SOURCE: Drive belt replacement
You may have a worn worm or sector gear.
You can turn the pulley for the transmission and see if the wheels turn that way. If they turn you may have belt run out or that cable may have come off at the bottom. Unplug before you turn any parts on the mower manually for safetys sake!
Good luck and be careful!
SOURCE: Disconnecting/bypassing the seat safety switch
I want to disconnect the seat shut off switch on my Husqavna 25 hp lawn tractor
SOURCE: Husqvarna YTH21k46 will not start.
check the oil level if its low you might have locked it up you should be able to move the engine a little by hand from the screen on top of the engine what color was the smoke?remove the spark plug and see if you can spin it over
SOURCE: where is the fuse in the husqvarna yth2146 located
they are just taped to the harness they are flat fuses not the old glass style
