SOURCE: Brother Sewing Machine CS-100
actually e2 is the button hole lever being down. e6 means that the thread is tangled and to prevent the motor from overheating the machine automatically stops. All you have to do is re-thread the machine and take the bobbin out, untangle it and put it back in and sew. This usually works. If it keeps happening, there could be a few things wrong.
1. if you are using thick fabric your tension should be lower. normal tension is 5.
2. your machine is out of alignment. take it in to a service center, they can fix it in 5 minutes. to find a service center near you go to http://www.brother-usa.com/service/
3. your needle is old or bent and should be replaced.
4. Your needle is too thick, standard is 80. The thicker the fabric, the thicker the needle.
SOURCE: I get an E6 message while trying to sew on my Brother cs-6000
Here is the online manual for your machine. http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000_ES_2000_EN_185.PDF
SOURCE: Error message on Brother SE-270D sewing machine
The safety device will activate if the machine has a bind or is unable to run at correct speed. If you turn the handwheel is it tight/hard to turn? if it is than thats it. Now what is binding the machine has to be diagnosed.
SOURCE: F2 error on brother sewing machine..what does it
On mine this means the button for reverse is stuck. Just wiggle the button a bit and it will pop out again. It can get pushed in at a slight angle and catch a bit, but nothing is broken... I don't know if this is the only thing F2 means, but it is one thing!
SOURCE: what does error E1 mean on a brother CS6000i
hello,the E1 code simply means the machine is working so hard,you can follow the information below to help you fix the problem,
The instructions for bobbin winding tell you to click the start button
for the bobbin to wind. When you do that you get that E1 with a
beeping. What they don't explain is that in order to press that "UP"
arrow button to get the bobbin to wind..........you need to UNPLUG the
foot control. So, in other words it to be used for sewing w/o a foot
pedal. Now instead of doing as per instructions, assuming you've
plugged everything in (foot pedal), after winding is finished just
press the foot pedal and your off and running or sewing as the case may
be. BTW, look it up in the TROUBLESHOOTING SECTION OF YOUR MANUAL.
please kindly rate the solution if it;s helpful,
take care.
