Question about Heavyduty Jazzy 1121 Standard & Heavy Duty Power Wheelchair
Jazzy 1121 power chair won't go
My mothers has a Jazzy 1121 Power Chair. The chair is fully charged, but does not move. The batties are brand new and charged. What might be the problem? there are 3 red, 4 yellow and 1 green lights flashing far as I can tell. any ideals? thank
  • Anonymous May 17, 2009
    I have a jazzy select. Its completely charged but will not move...the lights just keep blinking 9 times bit wont move at all!!
  • jLAKE Jul 10, 2013
    i HAVE A JAZZY 1121 AND IT CHARGES BUT I GET 3 RED 4 YELLOW 3 GREEN WONT MOVE.
    New Friend:
    Problem Solver:
  • 5 Answers
I find a lot of the controller Problems are caused by the cable running from the joy stick down to the controller gets caught on something or rubbed against something and one or more tiny wires inside are broken ... If I find a spot on the cable that is worn through, that's where I start .. Open up the insulation and check the tiny wires .. fine the broken one and repair it .. usually that solves the problem and saves you a couple hundred for the cable
Posted on Oct 08, 2011
It may not be the joystick. I have had the same problem before. The edel cable that goes from the joystick to the back of the wheelchair could be bad. You can try unplugging it and plugging it back into the joystick. Check the prongs on the cable and make sure their not broke. You can also try flipping the switch that is located down by the charger under the chair. The cable is around $200 and the joystick is quite a bit.
Posted on May 16, 2009
If your chair is run by a Pilot VSI controller, the error code----3 red/4 yellow/ 1 green---indicates a controller failure. I am having controller problems of a different kind on a Jazzy 1107 and it appears that few shops will work on the controller. Replacement is very costly.
Posted on Apr 14, 2009
SOURCE:
I have a jazzy 1121 and my seat moves around a little bit. How can I lock it?
Pride Mobility Jazzy 1121 - USA TechGuide
www.usatechguide.org/itemreview.php?itemid=570
19 posts - ‎16 authors Medium Back Seat Contoured Medium Back (standard). ... Comments: My jazzyscooter goes forward and side to side but the reverse makes a quick .... Strengths: Tough chair - town I live in doesn't have many curb cuts, but chair will climb ....Maneuvers poorly through (Handicap) doorways, due to rear locked caster wheels.
Nov 29, 2015 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Jazzy chair yellow light on the power control continues to blink. will not turn off.
yes nplug battery charger in and wait till batterys asre fully charged and turn off,if it doesnt u got water or moisture in the joystick and need a new one
Jan 06, 2014 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Jazzy power chair's battery runs out quickly afert being fully charged
I had the same problem I had to replace the batteries problem solved.But the batteries are not cheap
Apr 01, 2013 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Jazzy 1121 power chair won't charge when plug in to charge chair can move when you use joystick
you have either bad batteries or a bad charger or the charger might have come unplugged at the controller or power module. When you have the charger plugged in and you turn on the joystick the lights on the joystick should ripple to indicate the charger is plugged in. If you don't see this ripple then either the charger is bad or disconnected. Trace the charger cable from the rear of the chair (you have to remove the seat and shroud to do this) to the front module and make sure that the cable is plugged in. Hope this helps
Oct 22, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Can the speed of the Jazzy Power chair be increased beyond the setting on the armrest remote controller?
Make sure that your tires are properly inflated and that you are not carrying more weight than the power chair will allow and that your batteries are fully charged.
If you got your chair second hand, sometimes the previous owner has the technician change the controller settings to "dampen" it to slow it down to allow them greater response time and control. The technician can reprogram the controller to take it back to 100%. If you got the power chair new, it should be at 100% already.
Take it easy, HotRod. It's a medical device, not a car!
Jul 20, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
I have a Jazzy power chair on loan and there is no instructiion book. How do I recharge the chair? I know I plug it in but do nmot know if it is actually recharging, Thanks
Be sure to charge the chair at least 8 hours each time. If you use it charge it. If you charge it less than 8 hours than it starts taking away from the life of the battery.
Nov 12, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
How to push the jazzy wheel chair when power fails''
There are two levers located on the base of the chair on the left and right sides. Depending on the model, they will be located on top of the base on the front section of the chair base, or on the rear or on the lower sides. Most rotate 90 degrees to disengage the gears so you can manually push the chair. Others are moved up and down, or in and out. Return them to the locked position when done.
Jul 01, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Chair fully charged lrd lights flashing and chair wont move
Try using a Voltage meter to test the Voltage coming from your batteries. Your batteries should be as close to 12v. your motors are 24v. Even if just one battery is bad this can cause alot of headaches.
Jun 20, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
My Jazzy select wheelchair does not run
you move the joystick and can hear something quicking in the motors
May 17, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Mar 31, 2009 | Pride Jazzy 1113 ATS Indoor Power...
Heavyduty Jazzy 1121 Standard & Heavy Duty Power Wheelchair Logo
5,005 people viewed this question
Top Heavyduty Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Heavyduty Health and Beauty Expert? Answer questions, earn points and help others
