Plumbing Logo
Posted on Apr 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clogged sinks and toilets
Every so often my toilets do not flush down the water and my bathroom sink water goes down very slowly. Roto-Rooter wanted $700 to unclog the sinks but said that the toilets were not worth snaking . Can I use Draino without damaging my pipes?
  • ladycs Apr 26, 2009
    thank you so much for your input.
    Carole
  • Sam Gibson
    Sam Gibson Jan 21, 2016
    Great question about whether or not you should use Draino & if that could damage your pipes. Have you had the chance to get a second or third bid on how to fix this? I would imagine that most plumbing repair professionals could fix this issue. My parents had a sink that drained real slowly, I think they ended up needing to have the p-trap cleaned out.
clay
Level 2:
  • Expert 74 Answers
  • Posted on Apr 13, 2009
clay
Expert
Level 2:
Answers
74
Questions
0
Helped
56809
Points
179
Never use Draino on a toilet. All pipe cleaning liquids are not really a solution, just a temporary fix.
Since you said that the slow draining is associated with both the toilets and the sinks then I am almost certain that you have a venting issue.
Imagine a drinking straw.....now if you hold your thumb on the end of the straw and bring it up abouve the water level water remains in the straw. This is because air can't get in to replace the water. When your finger is removed then the water flows freely.
As with the straw, your plumbing must also breath. I would bet that one or more vents that are on your roof have become clogged with debrise. Squirrels love to throw nuts and stuff down there to build their nests upon.
Climb up there (safety is a priority) and try running a snake (~$10 at lowes) and see if you hit any obstruction. If so, use the snake to dislodge it.
If you would like, pour water down the vents either by hose or bucket and see if the water backs up. If it does then you have a clog. You can also use the water to try to clear the clog.
Thanks.
nieler
Level 1:
  • Contributor 3 Answers
  • Posted on Apr 06, 2022
nieler
Contributor
Level 1:
Answers
Questions
0
Helped
893
Points
21
A blocked sink can occur whenever and quickly. Nobody can hope for a blocked sink as it can destroy one's day. Sinks are significant in our homes, and when there is an issue, it can demolish a colossal piece of our everyday exercises. Sinks can get hindered with hair, oil, and different materials. your best option is calling a plumber at emergencyplumb.
Blocked Sinks in London
Paul Bissonnette
Level 1:
  • Posted on Mar 07, 2022
Paul Bissonnette
Contributor
Level 1:
Answers
Questions
0
Helped
1182
Points
11
Hi, We published a great article on how to unclog any drain please read the article to find the better solution.
https://allthingsdrain.com/how-to-unclog-drain/
Dave Anderson
Level 2:
Habit-Forming:
New Friend:
  • Expert 141 Answers
  • Posted on Nov 27, 2018
Dave Anderson
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
141
Questions
0
Helped
81544
Points
434
You might try calling someone to go take a look at your sewer. There could be something wrong with it that needs repair. A plumber would be your best bet since they have the training for this. http://ogradyplumbing.nyc/services/
Willis Brooks
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 30, 2016
Willis Brooks
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
893
Points
6
An inoperable toilet can be caused by a number of different things. Roots or other foreign objects in your main line, a full septic tank if you have one, calcium build up in the opening of the toilet, or even the matchbox car that your son wanted to see float.
Try the below tipwhich will help you to get rid of such situatrion as i tried it when i experianced such horrible situation at my residence.
1.) Get out the ol' plunger and make sure that there isn't anything right there that may be blocking the flow. If nothing pops out and the bowl water is clean, and I know this sounds gross, but stick your hand into the opening in the bottom of the bowel and see if you can feel anything blocking there. You shouldn't feel anything, but if you do then pull it out. While your have your hand there, you will notice if the interior of the opening feels gritty. Too much of that gritty, sandpapery type feel is calcium biuld up and can cause the very inner, and unreachable part, of the opening to acutally close and will case a slow or no flush. In that case grab 2 bottles of CLR. I reccomend doing this at night before bed so that the gasses will have time to work thier magic. Take the forst bottle and pour it dorectly into the bowl and flush. Turn off the water to the toilet. Then take the second bottle and pour it directly into the bowl. Cover the bowl with saran wrap and lower the seat and lid so that the gasses are contained. In the morning, remove the saran wrap, turn the water back on, and flush again. Beware the chemical smell will be strong. If that doesn't fix the problem, keep going.
2.) Ok. So you've followed #1 and nothing. Now I suggest that you go to Walmart, or your local hardware store, and purchase a toilet snake. Every home should have one of these, and Walmart usually sells them for about 5 bucks for a 5 foot snake. Follow the simple directions on the package and see if there is anything blocking further in out of your reach. If you can't get the snake to go all the way through, and it is not pulling anything out when you retract the snake, then you may need to remove the toilet from the floor and look from the other end. Make sure that you turn the water off before you do that though.
3.) Once you remove the toilet you will be able to see if there is anything blocking the inside of the toilet. If there is nothing visable, then stick your hand up the opening to be sure. Now that you have done that, look at the pipe in the floor. You should NOT be looking at standing water. If that is the case, try running the snake directly into the hose and see if you are able to remove anything.
4.) Ok. Still nothing. Next you will want to get some Main Line Cleaner for your toilet. You can get this at Home Depot for about 12 bucks. Now just think... If you have a plumber come out you are looking at least at $150, and that may not be the problem. Right now your cost is at about $20 if you had to buy the plunger. Follow the instructions on the bottle, but make sure to keep the bottle out of reach of little hands as this stuff is really toxic. If you have a large tree near your sewer line you may opt for root driller before the main line cleaner. It runs about the same price and can also be purchased at Home Depot.
You can also rent an electric snake (100 ft.) at Home Depot for about $50 for 4 hours if you want to try getting further down the main line.
5.) Still nothing? If you have a septic tank (like I do) you may want to go out into the yard with that trusty shovel of yours and remove the lid to your septic tank. Once you remove the lid, your sewage should be no more than 2 feet from the top of the tank. If you think it's a close call, it's time to call the septic tank people and have them pump your tank.
Despite what everyone says, how often your tank needs to be pumped depends on the size of the tank, when it was last pumped and the number of people using the toilets on a regular basis. The more it is used, the more often it should be pumped. According to the septic companies that I have talked to, and employed, you should really pump your tank about every 3 years as a preventative maintenance.
6)After trying all the above tips if still the problem exist then you have the only option left to call a plumbing company for sewer cleaning service to resolve the issue.
Water Sewer Line Repair
What is causing air in my cold water line and how do I fix it?
try running all the water in the whole house at once. all toilets. outside faucets, washing machine, ect...
assuming you have no leaks.
Aug 25, 2014 • Home
Model 81
Roto rooter the drain pipe in the wall. It's plugged. The water goes up the vent pipe to the roof that's why the water comes back in the sink when you shut off the disposer.
Toilet bowl will not refill
It is possible that the vent pipe behind the toilet is clogged (or was not installed properly). Some bathrooms are set up with one shared vent pipe, and a clog in one of the lines leading to it can cause similar problems.
The vent pipe in each bathroom does 2 things:
1: it lets the sewer gas go past the bathroom and up out the roof so you don't get sewer gas in the house.
2: It breaks the siphon as water goes from fixtures down to the big sewer pipes in the house. If it isn't working for a sink, it's not much of a problem because air gets mixed in with the water as it does down the sink, and this breaks the siphon. But in a toilet, it jsut keeps pulling water down the pipe until the water level in the toilet gets low enough to let air into the pipe, breaking the siphon.
It's not an easy problem to fix and often involves removing walls to get at pipes.
A plumber can bring a snake tool and try clearing the pipes from below or from the roof, and might even be able to bring a steerable snake that lets him control how it goes through the pipe.
Apr 19, 2014 • Kohler Home
Liberty Pumps Pro370 Basement Bathroom
At this point, opening the access cover is the last thing you do if it is below the water level in the pipes. Your system has a partial blockage in the pipes between the pump and external septic tanks or sewage dump site, that is the reason why when you use the plunger , half of the amount of waste water comes up to the sink and bathtub. You to open up your pipelines to remove blockage , probably tree roots in the pipes.
1helpful
2answers
Bathroom sink smells strongly like sewer when water runs fast.
Suppose you plugged the drain of the sink and filled the basin with water, then removed the plug. I must think that only after the basin empties you would get the sewer smell, and the smell would persist until you slowly ran some more water. If you try this, and this is the result, then the problem is that the sewer vent (that is supposed to prevent the water in the trap under the sink from being sucked down the drain) is not working right. If this is a new problem then you may be able to clear what is probably a blocked vent pipe. If this bathroom has always had this problem, then you have a poorly designed or executed vent pipe setup that you can only fix it with some surgery to your plumbing. However, to clean the vent you can try pouring a good bit of drain cleaner down the vent pipe on the roof, followed by water. But because there may be several vent pipes sharing the same vent stack out the roof, the drain cleaner may not get to your blockage and may simply go down a different path. Good luck.
Oct 15, 2012 • Plumbing
5helpful
Hi every now and again we are getting a sewer smell from our bathroom we have only recently moved in the house so not sure what to do, but it doesn't seem to happen all the time and everything flushes okay...
The smell may be coming from the sink trap if there is a problem with the vent pipe (that's in the wall from the sewer line to the roof). Do you ever hear gurgling in the sink drain when you flush? When you have the smell again, stick your head in the sink and see if that's where it's coming from. If you have a floor drain, the smell may be coming from there. In either case, a bit of water added to the drain will fill the trap and stop the smell. Please vote if you found this helpful. Good luck, Al K
I have an american standard toilet which is flushing slowly. i have it off and drained and am trying to get a roto rooter to pass thru it. i cannot get this spring thru the toilet either from the bottom...
If you have that thing off, take it outside and put it up on saw horses, fill the back with water and flush it, see if it is still slow. Then get your kid to reach up there and get his toys out if it doesn't flush. You might have to do it a couple times. Then if it does flush, you know it is clogged down the line or something is blocking the vent. Got squirrels? Check it out.
Kitchen sink clogged up , ran a roto rooter that you buy at the stores through the outside access and nothing happened. did the plunger thing on the sink and again its still backed up. I thought that...
Check the traps on the sink for clog and maybe if it has a turn in the wall it may be clooged .
You can disassemble the drain under sink and try and auger there.
Or if you can get acces to an air tank you can make up a fitting to screw on drain under sink and put air on it to try and free blockage.
May 06, 2010 • Plumbing
1helpful
2answers
My saniflow toilet is blocked and a plumber has told me i need a new motor. where can i get this and how much are they?
If you hear it making noise the motor isnt blown, but it could be clogged.
A quick an easy fix is by filling a 5 gallon bucket with hot water (or warm water) and slowly pouring it into the bowl. The warm water breaks the particles up further, and will help flush the unit out. Make sure you run the water alot after its cleared out (to flush the debris). You can do that by turning on the shower or sink (if connected). If you dont have a shower or sink just keep flushing the toilet.
Top American Standard Plumbing Experts
john h
Paul Carew
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
