have you made sure the video cable is plugged into the screen and the back of the computer correctly. You could also try a new video cable, because the problem may be that the wires inside the video cable have frayed. If that doesn't fix the problem you could try using a different monitor and see if you can replicate the same problem with a different monitor, if you can, the computer may have a problem with the graphics card. If you can't replicate the problem with a different monitor, it seems as though your northgate innovations monitor has developed an internal fault, if the monitor is within warranty try and get a free repair or get it replaced (if you have the receipt.
1.Drivers are usually given by the manufacturer to work with the latest OS (operating Systems). Sometime Windows 7 will detect the device and input the drivers it has in it "cab files" but if not present it will prompt you to look online to the manufactures website for updates or it will ask you to run the compatibility wizard . 2. Windows 7 has an option also to run the device in another operating system mode such as Windows XP and may have the drivers stored in the "cab files" for Windows XP for example. If not the manufacturers device will not run in the Windows 7 environment.
You have to open uo the set and check for 12vdc feeding the backlight inverter circuits, if you do have 12vdc then the inverter circuits may be bad, also look for bad caps. see example of a couple years old failed monitors: http://s807.photobucket.com/home/budm/allalbums
Most any monitor should work on your system. The only real limitations are the display capability of your video card. Most video cards will display up to a 22 inch monitor without any problem. Here are a couple suggestions
