Question about Dell Studio 1737 Laptop
Web cam says to close other video streaming application before it can proceed but there are no applications open
  • Anonymous May 19, 2009
    I am having the same problem...have you found a solution?
  • jojojohnin May 21, 2009
    I too having the same problem. Camera View pane is black and blank, and the LED light for the camera is turned off - even after opening Dell Webcam Central. Tt tells me to "close the other video streaming application" before I can use the webcam in Dell Webcam Central. This happens even if no other video streaming application is open.
I have an answer! I've tried many times to fix this problem on my laptop, even talking to two dell reps in the process(which was worthless). Finally I found the problem(for me, at least)- my webcam's driver was not compatible. If you haven't tried this already, go to your Device Manager, click the plus sign next to Imaging Devices, and select Integrated Webcam. Right click that and select Update Driver Software. I downloaded the latest driver it found and restarted my computer, and miraculously my webcam central was back to normal. I hope this helps you too!
Posted on Jul 08, 2009
  • Naveena Reddy
    Naveena Reddy Sep 01, 2010
    thank you so much...
    New Friend:
I had the same problem on two computers and finally tracked it down to the following. I was running a face recognition program for logging in to Windows and this app was always running in the background to be ready to accept a face when the computer locked. So what I do now is right-click on the app (FastAccess Face Recognition) and temporarily disable it - the Dell Webcam Central works fine. Afterwards I just re-enable the face recognition app.
Hope this helps.
---Andy
Posted on Jan 23, 2010
I'm having the same problem but where's device manager?
Posted on Jul 17, 2009
    New Friend:
Uninstall web cam central , it is just a software for you to take your own pictures and effects. But due to close other vedio streaming problem , the other applications in your pc like yahoo or skype which have vedio chat option do not detect your webcam. However if you uninstall your software , other applications will detect your webcam and work well and good. :)
Posted on Jul 06, 2010
  • selis Dec 14, 2010
    I have the integrated web cam problem with my Dell Inspiron 1440, 64 bit with windows 7 operating system. As a matter of fact it was working perfectly with Vista, but after I upgraded to Wiondows 7 it worked fine for some time, and then suddenly (I believe after some updates) it does not work any more. Dell webcam software gives an error message saying "close other video streaming applications" and my Google talk or Skype video does not work even though the Integrated WebCam 1.3 appears on their camera list. I tired every solution listed above includinn uninstallation and reinstallation, removing Skype, updating the driver, searching for new drivers on the web and installing them, non of them worked. I still get the same error.
    I would be very happy if someone would suggest another solution.
    Best,
    selis.
Press Start. Select Control Panel. Device Manager is in there in alphabetic order.
Posted on Sep 02, 2009
  • ag17 Sep 02, 2009
    One of the solutions posted i.e. to update the webcam driver did not work for me. Another solution on the site proposes that I do a complete reinstall. I will need to back up my whole computer before I try this. I will then make a posting to indicate if that worked.
2 Suggested Answers
SOURCE:
  • 508 Answers
SOURCE: web cam says to close other video streaming
Three possibilities of what might be going on
1- When you installed the web cam, windows found and loaded the drivers for it while you were putting in the install cd for the web cam and after you installed the software for the cam it tried to overwrite the windows install but didn't.
2- Are you using the same usb port that you installed the web cam into originally? if not then what happens sometimes is that windows looks for the drivers for this device under that usb finds the drivers for the original install and then opens them both up at the same time, giving you the illusion of two cams but only one actual cam.
3- Does your computer have a built in cam? if this is the case then when you open up your cam, you will have two cams trying to feed off one line, causing a problem, but only one cam will be showing up on your error.
Hope this helps.
Posted on Jan 14, 2010
Okay my web cam is saying that i need to close the other streaming application and i dont know what else is running
Hi. it is easy to find out what applications are running on your computer at any given time. Your computer may have come with a web camera application (mine did), and if that is running, it may not allow you to use the camera in Skype or other video streaming software.
To find out if there are other streaming programs running on your computer, do the following:
1, Press CTL+ALT+DEL 2. Select "Task Manager." 3. A list of all running applications are displayed. To ens an application, select it and click "End Task."
I hope this helps.
Jul 27, 2011 | Dell Studio 1737 Laptop
Tip
How to use your mobile phone camera as Web Cam.
Here’s a very useful free tip that will let you use your Mobile Cam as Web Cam.
All you need is a mobile (preferably Nokia) with a camera and some third party application to use your mobile as web cam.
Pre-requisite is both your mobile as well as your system must have Bluetooth.
First search for some applications which allows you to use your mobile camera as web cam.Wwigo and Mobiola are my favorite applications for this purpose.Just install Mobiola on your system and after that send the sis file to your mobile.Install Mobiola on your mobile also.
Switch on Bluetooth on your mobile as well as system.
Open Mobiola application on your system.You will see a Ready message.
Now Open Mobiola application on your mobile and connect to the system.
Thats it !
Now you can very easily use your Mobile Phone Camera as Webcam and enjoy video call and other things
on Apr 29, 2010 | Computers & Internet
I have a sony vaio with built in web cam and windows 7 but i cant use the web cam . why is that?
Are you using the Sony Webcam companion? If not ou can download the application from Sony Vaio website. ( Sony Web Cam Companion ). If you are trying to use skype or any other video messaging software: Try to check if there are other video chat application running in the background of your computer. Open the system configuration utility (Windows key + R > msconfig ) then go to the Startup Tab. Uncheck all application that is related to video chat and leave the preferred video chat software active (checked). Restart the computer and viola! You can now use your webcam for video chat.
Jul 04, 2011 | Sony VAIO EE Series Notebook VPCEE31FX/WI
Lifeframe webcam on an asus laptop, says camera is used by another program
Don't open two programs that uses webcam, for example: if you have skype application opened with video call you can use the webcam at yahoo messenger. make show application that requires one web cam features like video calling are online opened when needed.
if the is a hidden program that you sure to have close it that is still in process, then open the task manager and click on applications, you will see and end it process there, if the problem persist then restart the computer.
May 16, 2011 | Computers & Internet
Web cam says to close other video streaming application before it can proceed but there are no applications open that I know of.
try and install the right driver for this device ...that's why it says this ...it sees all wrong ...the issue with windows 7 is that does not have drivers for cameras or elder devices....if it is a built in camera ....just try to get in touch with the manufacturer and see if there is any drivers for the camera ...also ...you can try the driver for vista on 64 ...usually works ..but this is not a rule...
if there is no other chance ..until the driver will appear on the internet ...just get another camera with driver compatible with this operating system ...or roll back to vista or xp ...cause this oS is not that great anyway ...its slow...hard t use...and strange...
Jan 14, 2010 | Dell Studio 1737 Laptop
I have had problems with streaming video during
Doing my best to give you a correct solution and understanding
Issue : delays in streaming video
Environment :
ISP : Bellsouth
Router : wireless WRT150N
Solution :
"Downside to streaming"
Traffic jams.
Internet isn't a direct pipeline from the source to you. Streamed content passes through many other computers on its way to your computer via your ISP. If any one of them is carrying too much other traffic, the streamed content may be interrupted and pause. Streamed content is "buffered" to help avoid this, but sometimes it's unavoidable.
(test the downstream and upstream speed and alose test the download )
(Checked deleting the temporary files and folders)
(Checked firewall and Anti virus)
A slow computer :
if you have too many applications open, it could slow down your media streaming. If you notice things are sluggish, close all unnecessary applications and windows running on your computer. Just keep your Web browser and your media player open.
Noisy phone lines.
phone line that isn't free of noise (humming, crackling), that's not good for streaming (or Web browsing). Disconnect any phones that cause a buzz or hum.
Jan 02, 2010 | Linksys WRT150N Wireless N Router -...
"close other video streaming application to start video"
The same thing happened to me. But I believe this happened because I upgraded my Vista from 32-bit to 64-bit. How I solved it? The same way someone earlier suggested: update the driver:
1. Start the device manager (Click Start, type "device", and then click on "Device Manager" which appears as part of the search)
2. click the + next to "Imaging Devices"
3. Right click the "Integrated WebCam"
4. Click Properties
5. Click the option "Update Driver"
6. Automatically the updated driver will be loaded.
7. Restart your computer.
Hope this works for you.
Jul 22, 2009 | Dell Studio 1737 Laptop
Close the other video streaming application to start video
Your camera is already online. Double click the camera icon in the lower right task bar and it will work. That is the problem, the program is trying to run twice. Again, the camera is online and working and the access to it is in the task bar at the bottom. You, of course, can change these setting if you like.
Jun 21, 2009 | Dell Studio 1737 Laptop
HI.I was watchinglive streaming but there is a eror sudenly.this eror:rtsp://78.129.143.64/broadcast/pull/81.31.32.47:2030/broadcast/pull/81.19.7.50:3051/stv3.rmvb Can you help me...
Streaming audio/video quality can be affected by connection rate and Internet congestion. Many types of interruptions between your computer, your player, your computer's OS, your local network, your ISP and a streaming server can exist and cause trouble....
When you listen to the live audio/video stream, the sound or video skips, cuts out or buffers if the player doesn't have enough network bandwidth, it will buffer. Try increasing your player's buffering setting.Also:
  • Make sure you are choosing the appropriate bandwidth version of a media stream based on your Internet connection.
  • Make sure you are choosing the appropriate bandwidth settings in an Internet media player or streaming audio/video recorder.
  • Make sure NOT to download applications or files while watching/listening to media streams. Your Internet connection is shared between all open applications including your web-browser, your download manager and your streaming player. Closing applications that use your Internet connection simultaneously with your streaming player may reduce buffering.
  • Close other unnecessary applications that may be open on your computer. Reboot your computer. If you have lots of other programs open, they may be using too much processor time and/or RAM for the player to work properly.
  • Make sure your Internet connection is fast enough to reliably listen to streaming audio and/or watch streaming video online. High speed Internet connection is recommended.
  • Make sure your computer is fast enough. If your computer is old, it might be too slow to play an audio/video stream regardless of what else it's doing.
  • Update your media players and streaming audio/video recorders regularly.
Internet congestion can slow down the delivery of the stream, make it difficult for you to connect or cause buffering. Often the interruption is temporary. Please try to connect a few times at different times of the day, if possible. If you repeatedly have problems connecting, please notify your ISP - there are often quick fixes they can make when they learn about your issue.
Try the above steps you will find a solution to your problem....100% it will work.....
Sep 18, 2008 | Computers & Internet
Web cam
hello,
i have solution for this question but only for msn.........i dont use skype messenger.........so first u install software of logitech properly in u r comp then open windows live messenger........click the tools>audio and video setup..then press next n then select ur cam logitech quick cam pro 9000.....n then u see ur pic on that box..then finish it.......now try use it it will work......
Feb 17, 2008 | Computers & Internet
Dell Studio 1737 Laptop Logo
14,000 people viewed this question
Ekse
Clive
Clive
