Question about Jet 3 Ultra Power Chair
Leaking oil out of both motors - Jet 3 Ultra Power Chair
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
U need both gear boxes replaced or new seals put in them,go to ebay and look for the motors with gear boxes for your specific chair or otherwise u will need to ordor them from a dealer and and have your insurance pay for them
Posted on Jan 20, 2014
SOURCE:
My 80 vertical 2 stage ingersoll rand is leaking oil from under the motor. What would be the fix?
The motor shouldn't have actual oil leaking from it. It could be oil migrating from a leak in a area close to the motor or oil dripping on the motor giving the appearance the motor is leaking? If it's a small amount of oil it might be the grease seeping out of the motor bearings.
Mar 03, 2018 | Ingersoll Rand Air Tools & Compressors
I have a 2004 Toyota highlander leaking oil, oil light comes on. Could it be the rubber rings?
a 2004 toyota highlander V6
this should be your engine type
The 2GR-FE is a 3.5 L (3456 cc)
if leaks are that bad
always check the engine oil level before you drive off
fixing oil leaks on motors
degrease whole motor top and bottom
start with replacing the oil sender it may be the cause of the oil light coming on
after degrease
lay cardboard or paper under the car
take out for a drive and park over the paper over night
this pin points most of the oil leak locations
leaks from a V6 motor
rocker covers/ spark plug tube 0 rings.engine seals
cam seals
front and rear engine seals leak often
sump gasket can leak
if oil consumption or light on continues
can be a failing engine oil pump
or worn main bearings giving low oil pressure to the whole engine
you could be burning oil from worn piston rings
or hardened valve stems
a mechanic can fit an oil pressure gauge to the motor when hot
to check running oil pressure to confirm low oil pressure
if engine is worn out
it is possible to fit a lower mileage used motor to your highlander
its often cheaper than and engine rebuild
Oct 13, 2016 | Toyota Cars & Trucks
OIL LEAK IN FRONT MOTOR
1st check your oil pan plug. It's one screw underneath the car that is used to drain the oil during changing......next check the oil filter...If its loose, it could be leaking...if not either of these, could be a serious problem........
Jan 21, 2014 | 2003 Kia Sedona
Excessive Oil leak on 1985 Chrysler Laser 2.2L (non-turbo). My 17 year old son purchased the car with little history. Noticed a small oil leak on driveway. Replaced the valve cover gasket and leak...
A plugged pcv system will cause excessive oil leaks. But it sounds like you have a massive leak. If the passenger side is leaking behind the timing cover there may be up to four seals that may leak.single cam motor will have one cam seal dual will have two cam seals. Crank seal and possible oil pump seal. Would recommend pressure washing motor, go to local parts store and get some engine dye. Then support car and let engine get warm. And try to pinpoint leak.
Oct 01, 2013 | 1985 Chrysler Laser
1994- Chevy Cavalier V6 3.1 engine - leaking oil problem. every 2 months I am replacing the oil because it leaks
it is probably the o-ring in your oil pump. I have the exact problem in my Cavalier. it is a little expensive to fix and I believe you practically have to pull the motor to replace it. Just keep oil in it and you might want to wash down the motor compartment area to cut down the oil spray areas. Don't use a cleaner that will make it too clean because with a motor that oil you may cause more leaks. Sometimes with an old motor you need the build-up around certain sealed parts to fill gaps because it is an older motor. I had that problem with my Old mustang may she RIP, i used a detergent oil because I was told to and it started leaking 3 - 4 qts. of oil weekly and didn't before I used the detergent oil.
Mar 11, 2012 | 1994 Chevrolet Cavalier
1993 Yamaha TDM 850 oil leak starter motor area
Hi, Yorkgymoo1 for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://super-tenere.net/forum/xtz750-power/24656-oil-leak-from-starter-motor-area
Oil leak near starter motor Nuts Bolts Wrenching and Scratched Knuckles...
Yamaha TDM850 1996 Service Manual
OEM parts for Yamaha
YAMAHA TDM850 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 08, 2011 | 1993 Yamaha TDM 850
I have a 1996 Toyota rav 4 that leaks engine oil. The oil appears to come from the rear of the motor just below the valve cover gasket. Facing the car the leak is on the left side rear of the motor. The...
same here on my rav4 1996,i just put in oil stop leak been ok for 8 months :) you will always get hatters of oil stop leaks,but they work ok,though i find don't like them have never used them
May 19, 2010 | 1996 Toyota RAV4
Engine oil leak
It depends on where the oil is coming from.
Apr 22, 2010 | 2004 Mazda RX-8
Leaks oil on the exaust.smoke comes up from back
the tapping is probably from low oil level,you need to keep it full untill you repair the oil leak
Dec 28, 2009 | 1995 Honda Accord
Jet 3 Ultra Power Chair Logo
85 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
