You have a bad water inlet and it will need to be replaced. Here is the part to order. To gain access to the valve, disconnect the power cord, remove the top plate and you will see the valve.
SOURCE: Whirlpool washer f30 code
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
SOURCE: My whirlpool front loader washer leaks water
Check the rubber boot just inside the door. You have to push the drum back slightly and rub your fingers around the entire boot. I had a similar problem and a key had fallen out of a pocket and cut into that boot. The leak would run out of the damaged boot then come out the bottom onto the floor. I purchased a new boot and it took me about 30 min to install it. The problem was solved. If the rubber boot is fine then the over soap thing is probably your problem.
SOURCE: front load frigidaire washer w/ error code
The F03 code is a problem with your water system. your inlet valves may have failed.
Open up the bottom panel and you will find a tech sheet that explain the codes and gives trouble shooting techniques. here is the service manual, good luck, hope this helps......
http://frigidaireservicetips.com/pdf...icControls.pdf
SOURCE: F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
SOURCE: TROMM WASHER WM2277HW LG. GET IE ERROR AT BEGINNING OF WASH CYCLE
That noise means it is blocked. Did you get the filters in the back of the machine at the inlets? I've been through heck with this.... check out what finally worked.
IE= Inlet Error. I have struggled with this problem. After much trial and error it appears that it is due to my well water. People who have city water will probably not have this problem with this machine. Well water or hard water buyers beware. This machine is VERY much a primadonna princess capable of stopping your rinse cycle at the slightest imperfections. This is the Princess and the Pea of Washers... but I have a series of possible solutions that will have you appreciating her primadonna superiority once again.
Troubleshooting... Listen.... Does she sound like she is struggling and no water is coming in? If so then it isn't. The cycles will last forever as she makes all sorts of grunting noises. Something is preventing the water from coming in. It could also be that the pressure in to the washer is under 55 psi.
a. I have adjusted the pressure in the pumphouse to allow for minor fluctuations so that the machine will have at least 55 psi.
b. Take off the hot and cold inlet hose and clean the screen at the back of the washer. The two screens are supposed to come out of the male receptacles. They are fragile... beware. I use a squirt bottle/atomizer to clean these screens as mine chipped and will not budge.
c. You can add a screen just off the faucets so that you don't have to move the machine each and every time you get an IE error. This helps but does not solve.
d. I installed a faucet filter that I bought from Home Depot in the PVC sprinkler's section. They are made of a black plastic material and can easily cross thread, so be careful. They look about the size of a one liter container and unscrew midway to reveal a removable cylindrical mesh filter. This makes it possible to widen the surface area where tiny particles can be trapped without totally blocking flow to the inlet sensor. :-) When installing this make sure to completely rinse the hoses, and all screens coming into the machine. I took the shortcut first and thought my idea had failed only to discover that the screen behind the washer was partially blocked.
e. Periodically remove the filter and clean. Depending on the quality of your water, you may need to do this at all the points that have a screen.
I now have a screen washer between the sprinkler system filter and hose and the one that comes installed inside the male ends of the inlets for the water hoses. This has helped enormously.
f. Another possible offender is the soap and softener dispenser. To remove and clean press down on the plastic toggle piece on the soap side, the whole drawer should slide off and clean. Non-HE detergents and softeners can create a buildup of gooey gunk. Just clean it. Inside the drawer space you can clean to increase flow. I use baby wipes.
g. Make sure that the filter on the bottom is free from obstructions. If there is water in the drum, you will be flooded if you remove. This is a last resort after all the inlet lines have been cleaned and cleared.
Note: It doesn't take much to lower the flow of water to the point that this machine will not run. Since you cannot override the computer on it to run a spin cycle or even advance to remove water it can be highly frustrating. I've learned to obey my machine and just clear every last possible inlet.
Best of luck.
