SOURCE: screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
SOURCE: polaroid tda-03211c no picture
I was just looking at my manual for mjne and there is a fuse behind the set in a small plastic box you might check it
SOURCE: reset button on TDA 03211c
screen faded to black after very small amount of smoke, strangely it did not smell electrical. the pic is slightly visible when i shine a flashlight on it.
